Whats the most power
Old Sep 8, 2009 | 07:54 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default Whats the most power
From a standard 4x4 engine with standard t3 but with greens, exhaust and 3 bar
Old Sep 8, 2009 | 07:56 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
330 if your lucky imo on a good day
Old Sep 8, 2009 | 08:00 PM
Martin Hadland's Avatar
Martin Hadland
But with a short turbo life too
Old Sep 8, 2009 | 08:05 PM
JTECH James
Passion for Fords!
yeah the t3s do make funny noises over 300
Old Sep 8, 2009 | 08:26 PM
ASHCOSSIE's Avatar
ASHCOSSIE
just sorting a engine off of pete with a t3 on it and am going to run it in stage 3 with the standard t3 what the most boost would it be safe with and are the fairly low lag and nicer to drive than a t34 car
cheers
Old Sep 8, 2009 | 08:50 PM
LHD220Turbo's Avatar
LHD220Turbo
cheers
go for a t34.48 minimum
but if you want to stick with a t3, then you dont want to go beyond 26psi peak and 22psi held, unless you like changing turbo's
a t34 is proper stage 3, t34.48 is good turbo for the road, but any bigger exhaust housing than than then your injectors will be the limiting factor if you want to get the most of the turbo
a brilliant all round road engine is, 500 cooler, t34.55 or .63, siemens 55lbs with a chip to suit. i ran t34.55, siemens 55lbs, 500 cooler, msd chip. peak 30 psi, held 27ish, awesome for the road (365hp ish)
edit: if this is going into a 4x4 car with standard MT75 box, then i wouldnt go beyond 350/350 for the sake of the box
Old Sep 8, 2009 | 08:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
310 - 315 is realistic.
Old Sep 8, 2009 | 09:17 PM
Staffi's Avatar
Staffi
Didn,t Twellsies make 326bhp with similar torque on Martin,s Rollers using the NMS Gunship?? i think also this was @ 26psi and he,d had it for near on 3yrs i think....so there are exceptions..Lol..
Old Sep 8, 2009 | 09:20 PM
JTECH James
Passion for Fords!
3 years on most cossies is about 20 miles tho
we do a range of chips with a big spike in boost also
Old Sep 8, 2009 | 09:25 PM
Twellsie's Avatar
Twellsie
correct, had that set up for nearly 4 years and used it everyday
Old Sep 8, 2009 | 09:31 PM
Staffi's Avatar
Staffi
Thank you sir..........
Old Sep 8, 2009 | 09:32 PM
749steve's Avatar
749steve
my 2wd was running 327bhp that was stage 3 set up with a standard t3 turbo. it has lasted 40,000 miles before the turbo let go
Old Sep 8, 2009 | 09:34 PM
JTECH James
Passion for Fords!
i suppose you get lucky sometimes, i did 70k miles in 3 years on my t34 at 36psi, and it was fine even though on paper it should have shit itself after 5 miles lol
Old Sep 8, 2009 | 09:38 PM
749steve's Avatar
749steve
i wouldnt say lucky as i have only done around 2000 miles of the 40,000 before it shit itself
so im now saving for a t34
and once its fitted will head over your way for a propper set up
Old Sep 8, 2009 | 09:42 PM
JTECH James
Passion for Fords!
cool mate, good plan
Old Sep 8, 2009 | 09:44 PM
Staffi's Avatar
Staffi
Now that does deserve a hand clap James, especially having 36psi shoved through it...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
