Sierra engine conversion advise!"
Old Sep 8, 2009 | 03:30 PM
MJC's Avatar
MJC
Default Sierra engine conversion advise!"
I have a MK1 Sierra which I'm considering doing an engine conversion on. It currently has a 2.3 V6 Cologne engine and I'm considering the following options:
1. 2.9 24 valve Cosworth engine from a granada or scorpio.
2. 3.0 24 valve engine from the present mondeo i.e. ST220.
The advantage of the newer engine being its slightly larger capasity and the fact that it has an alloy block so should be quite a bit lighter.
However, I am not sure if it is possible to fit these engines to the Sierra as they are obviously designed for front wheel drive and also if a suitable gearbox can be mated to it.
Can any of you advise?
Old Sep 8, 2009 | 03:36 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Stick with the 24v idea, a lot cheaper to do and can be made to make 220bhp for little cash.
Steve
Old Sep 8, 2009 | 03:38 PM
m4tt274's Avatar
m4tt274
im not sure about the mondoe unit, but the granada 24v is a peice of piss to install it uses the sierra mounts, only the electronics can be fiddly and in my opinion it looks better. but if u do manage to install the mondy unit id love to see.
my neigbour has a red st220 and it seems to do the job, although it dosent sound as good as my 24v cos, and it dosent seem as quick, i know its meant to be 220bhp but on the motorway it cant keep up with the cos
Old Sep 8, 2009 | 03:42 PM
Loads of options for rwd cossie lump, done loads of times.
Old Sep 8, 2009 | 05:46 PM
MJC's Avatar
MJC
Thought I'd check incase as I saw a modern mondeo lump really cheap, but by the sounds of it its probably not a good idea. Thanks for everyones input!" Think I'll stick with the older cossy lump
Old Sep 8, 2009 | 05:47 PM
Jim Galbally's Avatar
Jim Galbally
2.9 granada cosworth will be the best value for money engine swap you can do for sure
Old Sep 8, 2009 | 06:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
another one in the "24V" column
Bailes1992
Aug 16, 2015 07:14 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
