Radio problem after jump starting
Old Sep 8, 2009 | 12:55 PM
arhopkins3's Avatar
arhopkins3
Default Radio problem after jump starting
Hi guys, I wonder if you can help me at all with this...
I had to jump start my 1998 Fiesta the other week because the battery had died (left my sidelights on)
I jump started it using my friends car, but their car had the negative as RED and the positive as BLACK and I hadn't noticed. So the leads were back to front and they melted. Luckily, I had a second pair of leads which,wired correctly, did the job.
The problem now however is that my radio doesn't come on at all. Ive looked at all the fuses in the fuse compartment and they all seem fine.. I've swapped the fuse around and it does nothing.
Removing and replacing the small security panel does nothing at all..
Is there anything else I can check or do I need to completely replace the entire stereo system?
Many thanks for any help and advice
EDIT: If I purchase a new standard stereo, how does it fit in... given that the fiesta stereo (CD) is not a normal size?
Old Sep 8, 2009 | 01:25 PM
RUPERT THE BIG HAIRY BEAR's Avatar
id say uve fried the insides off it
Old Sep 8, 2009 | 03:32 PM
I'd say be grateful, it does sound like you've fried the stereo, but are very lucky you didn't fry the ecu as well.
The stereo's can be repaired, me mate is a repair agent for pretty much all makes, but would imagine wouldn't be cost effective, he may have "b" graded new ones cheap though, pm me the number and I'll ask if you want.
Old Sep 10, 2009 | 11:33 PM
NUTS RuS's Avatar
NUTS RuS
Most stereo's have an inline fuse in the positive or permanant live feed.
Check that one to see if you have missed it.
Some older ones also have a fuse on the back panel depending on how old the radio is.
Fordmad!
Sep 26, 2015 05:24 PM
Daisychain
Aug 22, 2015 08:12 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
sridgett
15
Aug 3, 2015 07:26 PM
