erst breathers, smoking car
Old Sep 7, 2009 | 03:34 PM
utternutter's Avatar
utternutter
Default erst breathers, smoking car
smokey s2 im presuming its rings, however when you remove the filler cap i would expect to see excess vapours etc and there are none present, the car does stall when its removed does that mean the breathers are working ok?
i removed the hose from the turbo no hint of oil and the turbo has no play atall
car smokes on idle hardly atall when you put foot down when driving etc, if you sit at a standstill reving it high it does smoke, oiley smelling too and its oilyish in the tailpipe.
any advice, im just trying to eliminate possibilitys first
Old Sep 7, 2009 | 04:31 PM
utternutter
can anyone advice me atall please
lee
Old Sep 7, 2009 | 04:49 PM
orionmojo's Avatar
orionmojo
"car smokes on idle hardly atall when you put foot down when driving etc, "
This makes no sense mate. i'm struggling to read it after the third go
Old Sep 7, 2009 | 05:06 PM
utternutter
lol sorry it smokes on idle, and when rev it etc, but when driving no visual plumes from the rear
just took the breather thing off by rocker cover, i could blow through the one to meter unit and the rocker hole was clear, one to sump i could also blow through so its not that either
so it is lookink like rings i spose
Old Sep 7, 2009 | 06:17 PM
Oranoco's Avatar
Oranoco
I would expect rings to smoke under load not at idle. When you take teh oil cap off when idling does the car die?
Old Sep 7, 2009 | 06:47 PM
orionmojo's Avatar
orionmojo
a mate had this and his turbo was knackered.
loads of white smoke regardless of what the engine was doing, idle, driving or on boost. all the same
Old Sep 7, 2009 | 06:59 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
to me it sounds like the oil rings, have ya done a compression test on it
Old Sep 8, 2009 | 08:34 AM
utternutter
i havent no, yes the car dies when take off filler cap.
my bro in law yesterday were looking at it same conclusion as above as a guess, the oil control rings, as i say took boost hose off turbo and its super dry turbo has no play
Old Sep 8, 2009 | 10:06 AM
coswurv's Avatar
coswurv
could try valve guide seals as there prone to failing on the cvh engine, my brothers had the same problem and that was the cause, does it puff a bit of blue smoke when first started ?. You can buy a tool to change these with the head still on the car so its cheap and easy to do so could be worth trying it if the compression results come back ok.
Old Sep 8, 2009 | 10:14 AM
RS Grant's Avatar
RS Grant
Made in Scotland
Would it not be better doing a leakdown test to check the health of the engine??
....and Valve Stem Seals tend to show on over run, so get car up to temp and drive to 4500-5000rpm, take foot off gas and let it run down the rev range itself on engine braking and see if there are any signs of smoke. If the valve stem seals are tired then they wont take the pressure and oil will pass.
Cheers,
Grant
Old Sep 8, 2009 | 10:18 AM
Danster76's Avatar
Danster76
Cheers,
Grant
I agree with that. I'd just do a simple compression test before getting involved with changing the VSS's although cheap and easy to do will be pointless in the GST if you're in for the big RB Good luck!
RsS2daz
Aug 14, 2015 05:26 AM
Adam-M
22
Aug 10, 2015 10:46 AM
Ellsa
Aug 9, 2015 07:03 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
