that pressure turbo use?
Old Sep 6, 2009 | 11:56 PM
pitjardas's Avatar
pitjardas
Default that pressure turbo use?
Hi, I would help if it is not uncomfortable on my rs turbo, my rs have a 195bhp powerchip, mfi to efi convertion, 10-15 psi actuator, intercooler Airtec, the head stage 3, piper 285t2, the car still has the mahle standard pistons, con road bolts ARP , dump valve forge motorsport, t3 turbo STD, I know that I can to pressure the turbo so that you do not lose the reliability.
Old Sep 10, 2009 | 12:26 AM
mercgrey's Avatar
mercgrey
you need a cossie pump and beige 701 injectors too buddy or you will run lean!
Old Sep 10, 2009 | 06:20 AM
pitjardas's Avatar
pitjardas
Hi, bosch 701 beige already have to work only the fuel pump is not.
with the fuel pump pressure that I use? I was thinking at 1.3 bar, does not break the pistons?
Old Sep 10, 2009 | 09:57 PM
Rob_DOHC's Avatar
Rob_DOHC
Fuel or boost?
fuel 3bar (i think)
Boost i would say 15-17psi.
Rob,
Old Sep 10, 2009 | 10:01 PM
pitjardas's Avatar
pitjardas
Talking
Originally Posted by Rob_DOHC
Fuel or boost?
fuel 3bar (i think)
Rob,
boost, sorry
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
