will these wheels fit?
Old Sep 3, 2009 | 05:40 PM
jamieRST's Avatar
jamieRST
Default will these wheels fit?
just wondering if these will fit ok on my s2.without rubbingit will be sat koni suspension with -25mm drop.7J X 17" ET40205/40/17 tyresthanks in advancejamie
Old Sep 3, 2009 | 05:44 PM
jonny s2's Avatar
jonny s2
You might need 5mm spacers for that offset
Old Sep 3, 2009 | 05:59 PM
RSandy's Avatar
RSandy
i ran et40 17x7s with 205/40 tyres on mine, and it was fine after the rear arches had a bit of a grind, but that was dropped like 80mm or something stupid. fronts are fine
Old Sep 3, 2009 | 06:00 PM
jamieRST's Avatar
jamieRST
ok thanks people
Old Sep 3, 2009 | 06:03 PM
T28 RST's Avatar
T28 RST
Ok then
Will be perfect
Mine were ET40 and the back only started to rub slightly after the rear discs were fitted.
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
borboyous
Aug 22, 2015 11:17 AM
cossynut2
Aug 19, 2015 11:29 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
cossie4x4
Aug 14, 2015 06:29 PM
