fueling not richening on boost
As per title,car just been on rollers and air/fuel is spot on at idle and low rpm/boost but once up over 3500 it doesnt become any richer,iv not got an amal valve on mine so was told to try fittin one of those but just wondered if you guys had any other suggestions?
it's probably the little black box on the metering head is broken or needs adjusting to richen fuel on boost or could be the tps is not reading wot which also is a trigger for fuel to increase on boost
No, according to the stuff i have read today the throttle position sensor has three settings, closed-open-wot.
The car (if bosch KE) will richen the mixture etcetc on WOT so this may be s possible problem... any one know of a good 5th injector kit?
Rob,
Rob,
Ok well thanks for the info guys,the car is rebooked at the rolling road and a friend of mine has got another tps,ecu and fuel computer so gonna try those and see if we get a solution
Right been back to the rollin road and tried changing the ecu,fuel computer and tps but nothing helped,we took the air box off and the mixure changed a bit but still not enough so could it just be that the metering unit is knackered?
I should think your metering unit is fine tbh mate, if the empr (or what ever its called)... the black box with a 2pin connector on the side of the fuel distributor is unplugged or has no signal etcetc, the metering unit will go to its 'base' mechanical 'map' (not strictly true but good for explaining), this base map is set up for a warm engine not on boost.
Ie if there is an issue with that part your car will not fuel correctly on boost and normally be a pain to start from cold.
There are numerous tests you can do to test this and all other sensors.
Rob,
Rob,
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
