boost gauge reading when idle
Old Aug 27, 2009 | 08:12 PM
stevenebm's Avatar
stevenebm
post whore
Default boost gauge reading when idle
whats it meant to be at when idle?mines is reading -5ish then heading up to 0.i cant for the life of me remember what its meant to do.sit at 0 etc.does this sound about right?
Old Aug 27, 2009 | 08:28 PM
749steve's Avatar
749steve
if its on mfi then the engine is at a vacum on idle and low revs so that is fine
Old Aug 27, 2009 | 08:39 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
mine in idle reading -0.8 bar
Old Aug 27, 2009 | 08:40 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
mine at idle used to read -9psi.
Old Aug 27, 2009 | 08:57 PM
cossieboj's Avatar
cossieboj
mine to!
Old Aug 27, 2009 | 09:29 PM
stevenebm's Avatar
stevenebm
post whore
cool guys thats fine.just checking as its the first its ran on mfi for 8 months.the charge carrier seemed very hot tho,maybe just being paranoid tho.
Old Aug 27, 2009 | 09:48 PM
jodyhoare's Avatar
jodyhoare
i thought it was ment to be -10 psi there or there abouts?
Old Aug 27, 2009 | 09:51 PM
stevenebm's Avatar
stevenebm
post whore
i havent got a clue mate.why would it be sitting at 5 instead of ten?
Old Aug 27, 2009 | 09:59 PM
Tim's Avatar
Tim
depends on cam etc
Old Aug 27, 2009 | 11:27 PM
jodyhoare's Avatar
jodyhoare
it also depends on what kinda revs your sitting at on idle, does the vacum also depend on what boost your running?
Old Aug 28, 2009 | 03:23 AM
jonny s2's Avatar
jonny s2
im sure mine ran -15,cant quite remember as its been that long off road for a revamp
Old Aug 28, 2009 | 07:06 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah mine is between -15 and -20, it does flap around a bit though. As Tim said it also depends on your cam, port work, etc..
If your not pulling much vacuum at idle (950rpm approx) then it could be a sign of piston rings wear, just like a compression test would be low for the same reason.
Old Aug 28, 2009 | 09:16 AM
Chris69's Avatar
Chris69
mines about -20 and lower when just coasting- glad to hear mines not the only one that flaps about a bit!
Old Aug 28, 2009 | 09:42 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
seems a bit low, should be around -20mm/HG
you don't measure vacuum in psi, only in mm of mercury
Old Aug 28, 2009 | 01:11 PM
JamboRS's Avatar
JamboRS
focus rs 1672
depends on several things where the needle sits as stated above
mines sat at 15
Old Aug 28, 2009 | 07:41 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
very true, a healthy amount of vacuum though, on a cold start it tends to be more(?)
Old Aug 28, 2009 | 09:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
lol yeah i'm not sure why the vacuum is erratic at idle?
But yes mine also drops to about -25hg when coasting.
Probably because the idle is a little higher on a cold start, if anything it would pull less vacuum cold because nothing in the engine has expanded and nothing is seating/sealing (rings, valves, etc..) as well as it will when warm.
Old Sep 1, 2009 | 10:38 AM
dan-dan's Avatar
dan-dan
Mine vacums to anywhere between -15 to -20 and lower on overrun, if you didnt have much vacum could it be a sign of a leak after the flap?
Old Sep 1, 2009 | 11:21 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Which flap mate, metering unit?
Old Sep 1, 2009 | 02:53 PM
jodyhoare's Avatar
jodyhoare
flap? lol is that a technical term?
Old Sep 1, 2009 | 03:05 PM
Herbo747's Avatar
Herbo747
yeah mine sits between -15 and -20 somehwere around that general region.
Old Sep 10, 2009 | 07:52 PM
dan-dan's Avatar
dan-dan
sorry by flap i mean throttle butterfly thingy
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
