help needed! engine wants to die when braking
Old Aug 14, 2009 | 07:12 PM
shaggy85's Avatar
shaggy85
Default help needed! engine wants to die when braking
as mentioned above when i press the brakes the engine want to cut out, any ideas why???
Old Aug 14, 2009 | 07:40 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
engine running too lean and air from servo is making it more lean causing a stall?
that's all i can think of.
Old Aug 14, 2009 | 10:38 PM
Alvyn's Avatar
Alvyn
what car? but more than likely one of the pipes that goes to the servo/inlet is faulty!
Old Aug 15, 2009 | 07:17 AM
shaggy85's Avatar
shaggy85
Originally Posted by Alvyn
what car?
its an '85 escort xr3i
Old Aug 15, 2009 | 10:09 AM
Could be split diaphragm in servo, but most likely a dicky one way valve jammed open(in vac pipe), just disconnect the servo vac pipe and try, remember the brakes will be harder to push though.
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
