fuel pump supply hepl!
Old Aug 9, 2009 | 03:05 PM
goldengraeme's Avatar
goldengraeme
Default fuel pump supply hepl!
hey, needin some help, the cossie decided he wasn't going to start on thursday so had a quick look and put it down to the engine not gettin fuel. so i started to day by checking the fuel pump fuse its ok, i then checked the fuel pump relay and again its ok to, so i thought it was the pump i've dropped the tank and put a direct supply on the pump bt its fine as well. what i've found is the connector at the back bumper there is no supply to it. oh i've also checked the fuel cut off sw its ok to.
really need some help please
all ideas welcome.
cheers
graeme
Old Aug 9, 2009 | 03:49 PM
goldengraeme
ok looked at it a bit more its pin 28 on the ecu and thats whats stopping the fuel pump starting. anyone know why this would be?? could it be a faulty sensor??
cheers
Old Aug 9, 2009 | 11:57 PM
lloydmotorsport's Avatar
lloydmotorsport
cosworth parts specialist
the ecu starts the fuel pump when the engine is turned on,
so does the fuel pump prime when the ignition is turned on?,
check the cps,crank position sensor.front pully by the radiator.
and the sensor in the distributor.you can buy these cheap from matt lewis on here or ebay.
Old Aug 10, 2009 | 07:03 AM
goldengraeme
Hi no it's not priming when i turn the ignition on i'll have a look at them tonight cheers. A mate who has owned cossie's think's it could be the map sensor any chance it could be that. Prior to it not running at all every now and then it would play up would only boost to 0.3bar and when you hit 4k it would cough like a miss fire. He think's it was the map sensor giving up. Cheers for your help.
Old Aug 10, 2009 | 07:50 AM
rog's Avatar
rog
Crank position sensor i'd say.
Old Aug 10, 2009 | 12:24 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as above, the cps should send a signal to ecu and when it picks up over 250rpm (iirc) it then sends a signal from ecu to switch fuel pump relay on.
Old Aug 10, 2009 | 02:07 PM
goldengraeme
Cheers dude's i'll try that there only 25 sheet's so i'll get one and see if that sort's it. This YB thing is new to me. Give me a Peugeot engine and i'm sorted. but cheers again for the help
Old Aug 10, 2009 | 02:55 PM
rog's Avatar
rog
Where are you located, are you in Keith or is that a different keith to what I'm thinking??? I have a spare CPS if you want to borrow it to give it a try.
Old Aug 10, 2009 | 09:48 PM
goldengraeme
hey yeah i'm in keith outside aberdeen. working in cults at the monent, would be ace to get a wee shot to see if that's the problem think it is cause i Took out my cps tonight one it was covered in oil and crap but the outer pvc had worn through so i think it's been grounding out on the block. hope that's the prob.
Old Aug 11, 2009 | 07:23 AM
rog's Avatar
rog
No worries I'll PM u my number.
Old Aug 11, 2009 | 09:36 AM
goldengraeme
Cool cheers dude.
Old Aug 15, 2009 | 11:04 AM
goldengraeme
Well thank's everyone for your help. Rog you the most for giving me a loan of the cps. Popped it in and the fuel pump relay pop back into life. Got a new one ordered so hopefully the escos will be back on the road next week. So cheers again everyone.
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
NC53
Sep 13, 2015 03:05 PM
