metering heads
tried setting the mixtures on my s1 (mfi) but the adjustment screw is not the proper one..it has a small bolt instead of the allen type (i think thats correct?)..the car runs but is quite lean..co level only 1.6% instead of 3% so ive been told..what im wanting to know is can i put a longer bolt in it as i think the screw needs turning more clockwise to increase co level..also what other things have you done to replace seized mixture screws..cant seem to get hold of a good second hand 1 with allen screw intact and not seized..thanks
It might be that the bolt is simply the bung to prevent an air leak, and if you take it out the allen key adjuster is underneath, thats whats normally done. Otherwise If what you say is accurate then the metering unit will need stripping down to remove it if it is seized!!
thanks for that...when i removed the bolt the car cut out so does sound like a bung like yous said..i was getting a bit of difference in co level but not very much..do u know what direction the allen screw needs to be turned to increase co level..thanks again
Cutting out is a good thing, means your breathers are not blocked
Clockwise is rich, anti is lean, 1/4 of a turn will make a difference to how it idles so should notice as you are doing it!
lol! You hold it on the throttle body so it doesnt stall, once you have inserted the allen key it should not stall anyway, if it does then you are very lean! Just turn 1/4 clockwise and fire it up again.
Make adjustment and use your finger to seal the opening while taking a reading.
Remember that the original CO figure from Ford was 0.25%. To set it really rich is usually done just to compensate the fuelling for higher than standard boost.
Mc5506
Oct 5, 2015 09:57 PM
