8 injector setup?
Old Mar 1, 2004 | 03:28 PM
Default 8 injector setup?
right, im thinking of buying one of these for use in the near future,
thing is im not to sure what else i would need to get it set up on my l6 ecu.
i know i would need another set of greens and a live map but not to sure how or what i would need to get the second loom working?
anyone help me out please?
Old Mar 3, 2004 | 02:19 PM
Spinza's Avatar
Spinza
Darren i maybe way off and probably am but i think you need L8 to run 8 injectors.
Old Mar 3, 2004 | 02:23 PM
PJay's Avatar
PJay
You are way off
Old Mar 3, 2004 | 06:49 PM
Spinza's Avatar
Spinza
Dunno why i thought that, but can you explain what he needs then Paul
Old Mar 3, 2004 | 11:42 PM
PJay's Avatar
PJay
8 Injectors with the correct soft/hard ware will work on any ecu, rs500's were Level1
Personally i favour 4 large injectors over 8
Old Mar 4, 2004 | 12:29 PM
Danny B's Avatar
Danny B
may inlet combined with SECS management= good power
Old Mar 7, 2004 | 07:53 PM
How much does it cost for the kit in the above pic??
Old Mar 7, 2004 | 09:10 PM
Sorry to jump on your post but wouldn't eight small injectors be more precise than four big ones?
(Question directed at PJay but anyone can answer )
Old Mar 7, 2004 | 10:46 PM
PJay's Avatar
PJay
All down to the mapper but technology today with these large injecors is good and they are spot on
Old Mar 7, 2004 | 11:18 PM
richm's Avatar
richm
modern ecu's will control single large injectors precisely enough to not be any problem.
One major benefit of 4 large injectors, is IF one goes down for some reason, you won't melt your engine, it will just run on 3 cylinders. If one of 8 goes down, it will almost certainly cause damage, as that cylinder will still be getting a weak mixture from the single injector that is still working..
Old Mar 8, 2004 | 09:31 PM
Just read some of the other 8 injector posts. Makes sense
mk3ste
Oct 17, 2021 10:09 AM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
