Ford Puma Discuss the Ford Puma here!
Puma rear shocks, possible fitting issue?
Old Aug 1, 2009 | 02:43 PM
jamiepeers's Avatar
jamiepeers
Default Puma rear shocks, possible fitting issue?
Hi all. My first post and i've had a bit of a scan around but can't find an answer. Maybe you guys can help.
I have a late 1999 puma 1.7, and have just changed the rear shocks for new ford items. They are the "eye" type not the "fork" type, although i don't think that makes a difference to what the problem is as they were changed like for like.
When i slid on the new top mounts, fed the shock into the rear of the car, then bolted the top "cup" on, after letting the weight back on the car, there is a small gap between the cup and the body of around 8mm.
However, when i take the shock off the car and bolt it up complete, the gap is still apparent and couldn't possibly be taken up as the thickness of the bodywork is around 1-2mm.
The top mount is tight to the bodywork and the locating lug is in the cutout in the shock tower on the body of the car. I can't see how the top "cup" bolts on any tighter to take up the gap
Has anyone had this before, is it normal? And if not can anyone help.
Everythings tight, and it doesn't rattle over bumps but i've a feeling somethings not quite right
Jamie
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
Ben26
Aug 11, 2015 04:19 PM
Red_bull
Aug 9, 2015 08:34 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
