Amal valve
Old Jul 28, 2009 | 03:33 PM
Barry R's Avatar
Barry R
Default Amal valve
What would stop the valve from clicking mine wont click now it has a new engine in
was fine before
But was a on a T3 now on a T34
Old Jul 28, 2009 | 05:09 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
have you changed the chip?
Old Jul 28, 2009 | 05:13 PM
Barry R's Avatar
Barry R
Not yet Rob
Old Jul 28, 2009 | 05:14 PM
Barry R's Avatar
Barry R
Not yet mate also my iscv aint working at all was sweet before
Old Jul 28, 2009 | 05:20 PM
saph cos rob
swindon rsoc
have you changed anything since it was last working?
JTECH James's Avatar
JTECH James
Passion for Fords!
amal valve and iscv share the same feed, so its a wiring issue pal,
i think they run from the fuel pump relay area
Old Jul 28, 2009 | 05:24 PM
Barry R's Avatar
Barry R
Ah that sounds good any idea what colour wires it is or is it just a trace prob
Barry R's Avatar
Barry R
Rob nothing was changed mate
Do they have a fuse or anything
Old Jul 28, 2009 | 05:30 PM
saph cos rob
swindon rsoc
sound like a wiring fault, and no i dont think there is a fuse its fed straight from the ecu... check the ecu plug etc etc....
you seem to be having way more than anough problems with that car mate lol
Old Jul 28, 2009 | 05:34 PM
Barry R's Avatar
Barry R
I know
Im going out to have a look now
Back in a bit
What pin in the ecu is the feed or what colour is it
Old Jul 28, 2009 | 05:35 PM
JTECH James
Passion for Fords!
the ecu provides the earth control, both amal and iscv have an ign live, run a continuity check and probe it out
Old Jul 28, 2009 | 06:19 PM
Barry R's Avatar
Barry R
I just Fucked it now had no power to either put a lie on the amal but touched the other wire tiny spark now no spark no pump nothing
Old Jul 28, 2009 | 06:21 PM
JTECH James
Passion for Fords!
you probably spiked the ecu if you sent 12v down the earth wire.
continuity check doesnt involve sending power anywhere
Old Jul 28, 2009 | 06:24 PM
saph cos rob
swindon rsoc
sell it mate
Barry R's Avatar
Barry R
Great what I NEED A NEW ECU THEN
Old Jul 28, 2009 | 06:27 PM
Barry R's Avatar
Barry R
I should sell it then
Old Jul 28, 2009 | 06:28 PM
JTECH James
Passion for Fords!
well, erm, it will need testing now to see if you fried it
Old Jul 28, 2009 | 06:30 PM
Barry R's Avatar
Barry R
Who can test it or is it a case of fit it in another car
Old Jul 28, 2009 | 06:31 PM
Barry R's Avatar
Barry R
The fuel pump fuse has blown I fitted a new 1 and nothing would it of mashed the relay aswell
JTECH James
Passion for Fords!
msd can test them,
you could do a visual check of the board to see if its crispy
Old Jul 28, 2009 | 06:34 PM
Barry R's Avatar
Barry R
The board and all look sweet and smell normal
Old Jul 28, 2009 | 06:37 PM
Barry R's Avatar
Barry R
Found a dry joint in the ecu
JTECH James
Passion for Fords!
well, my next step would be get the ecu tested then get a wiring diagram and pin out to check the ecu feeds and relay feeds,
but if your not confident get someone to help you
Old Jul 28, 2009 | 06:39 PM
Barry R's Avatar
Barry R
Cant I just set fire to the car and claim the ins
Old Jul 28, 2009 | 06:44 PM
Barry R's Avatar
Barry R
Its pin 19 thats dry any1 know what it is
Old Jul 28, 2009 | 07:19 PM
Barry R's Avatar
Barry R
Right I have resoldered it and it starts again the amal clicks after a second or 2 when
running but no ISCV
How do you test it the ISCV Can i just wire it direct to a battery and listen for a noise?
Old Jul 28, 2009 | 08:03 PM
siscossie's Avatar
siscossie
3-door moonstone
Default amal
Just had mine setup at noble motorsport there was a burnt out electrode in my ECU which stopped the amal valve working, they managed to fix it top blokes.
Old Jul 29, 2009 | 11:07 AM
Barry R's Avatar
Barry R
The amal works now but the i think my iscv is seized
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
