2.0 zetec st170 race engine - PRICE DROP!!
2004 30k st170 engine brand new rebuild to following spec
11.8:1 C/R
CFM billet oil pump gears
Lightened and knife-edged crankshaft
Lightened flywheel
AP racing paddle clutch and up-rated cover
Fully balanced bottom end inc. clutch assy
ACL Heavy duty aluglide bearings
ARP bolts (connecting rod bolts, main cap studs, flywheel bolts)
All machining to fit bolts/studs
Shot peened steel rods
Stage 3 head with piper up-rated valve springs
Piper BP300 cams (284° in / 278° ex, 11.44mm lift in / 10.60mm lift ex)
Pistons pocketed to suit
Bores honed and new ford rings fitted
Lifters shimmed to suit
Kent cams exhaust pulley
VVT blocked (reversible)
All new ford pumps and tensioners
Aux belt routed for non power steering but can be reverted
+ much more
All timed up ready for running in
Work carried out by Impulse Developments in Rochdale who built another engine with the BP285 cams running 245bhp with Jenvey 45mm throttle bodies and ST170 exhaust manifold with straight through system.
Spec to produce circa 250bhp+ @ 8000rpm with the right intake and exhaust systems
£3000 ovno, priced for quick sale. Cost in excess of 4.5k with all. Receipts for all parts and work available.
New baby and house force sale
11.8:1 C/R
Lightened flywheel
+ much more
I'll knock £300 off for that lot
VVT is variable valve timing, on the st170 engine the vvt is on the inlet cam only and moves 60deg from 85deg btdc to 145deg btdc depending on various factor such as engine speed, throttle position etc.
When you change ecu it can be quite hard to map it unless you go for something like a DTA S60 which can alter the amount of degrees the VVT moves gradually, otherwise you can use a simple ecu such as megasquirt and it will come in at a fixed rpm.
I removed the VVT because the cams I received from piper specified fixed timings and I couldn't afford an ecu such as the S60. However you can still use the cams with VVT if you know what you're doing but you won't have 60deg movement, you'd have to restrict it to about 30 so in my eyes that isn't worth it. However, Catcams do some cams which have increased lift and duration but keep the full movement of the VVT.
Hello
The problem with DTA and Megasquirt is, that the VVT will not be controlled in his pos.!
With these´s ECU´s it just will switch between both end pos.
Cheers Mark ( www.ST2000.de )
Hello
Hey GTI_tom is the engine sold?
11.8:1 C/R
Lightened flywheel
+ much more
11.8:1 C/R
Lightened flywheel
+ much more
I realise that the st170 engine is long gone (
), but after something just like this...Wondered if anyone is out there, offering the same or similar setup??? Budget is healthy, but certain spec is required, atleast 240-250hp.
Tim
), but after something just like this...Wondered if anyone is out there, offering the same or similar setup??? Budget is healthy, but certain spec is required, atleast 240-250hp.Cheers
Tim
hi there. Im looking for something for a winter project. So ideal would be within the next month or 2.
Why what you got on offer????
Ecu and tbs no biggie. Could get hold of some hayabusa tbs and modify....They produce some good power, and cost a hell of a lot of less than jenveys..Ecu, have been recommended dta s60 as can control vvt constantly.
What you got to offer???
sh1t just pmd you.. Its going in a westy, rear wheel drive.So the rods and pistons arent standard??? Cos the standard ones are pretty good anyway..Are you not looking to sell the ecu, cos thats exactly what Im after, and obviously itll be setup/mapped which would be worth a bit to me too... What work has the head/cams had? What sort of price roughly are you looking for?has it been dynod, what power is it producing?
I know im ahead of myself here... but Im on the lookout for an engine similar to this one (ive finished my current project (ended up with an s2000 engine))... or atleast a standard st170 engine on throttle bodies... not needing it till end of summer so no rush... but perhaps theres someone out there thinking theyll use it over the summer, and have other plans over the winter period? please get in contact if youve got a potential engine up for grabs.
cheers
cheers
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
