lap top batteries
whats a ball park figure on replacement batteries
i got it in me head that these are gonna be silly expensive and i might aswell buy a new laptop
where is the bet place to get them from?
Not very helpful without a make and model of lappy mate. Try ebay as you can get a real cheapy from China or Hong kong but makes sure theres a warranty. A new after market battery is normally bigger capacity and will last longer than the original. Dont rule out a Uk seller as it may be worth paying a bit extra incase there is a problem and it needs to be returned. Good luck mate
Regards.
Adam.
Regards.
Adam.
Ebay. Its worth spending an extra couple of quid tho to get one supplied from this country, china ones could take a couple of weeks to come through and you may get stung with import tax.
Try to get a genuine one too made by your laptops manufacturer
yeah guess it would of been a good idea to give model
its a cgr-b/458 for my advent 7302
only one i can find is one the bay and thats a 2nd aswell
so guess these are an old battery and obsolete or something
anywhere that would stock a new one?
I just looked for one for my daughters old DELL £50,fook that I only give £100 for it ages ago and we got her a new mini laptop last week for £200 so I wont be buying a battery for that old DELL Latitude.
Ebay is not where it's at.
I have ordered from the site below over 100 times, and NEVER been hit with taxes, if it's under a certain value no notice is taken.
Depending on age most of the lappys use 18650 cells, lithium ion/polymer, the packs can be taken apart carefully and re-batteried, not hard to do, newer ones will not only be vastly better performance, but also a high spec, as they are increasing all the time(mah).
Just look on www.dealextreme.com for the batteries after taking measurements, as there are stack loads of different sizes.
If you get stuck with the sizes I will be able to get info for you, it's not improbable on some to get 3 times the run time with decent upgraded batteries, that charge just as normal ie in lappy.
M K
Shows & Track Days
16
Nov 8, 2015 06:18 AM
Adam Graham
Sep 6, 2015 06:04 AM
