Turkish 200 Blocks
Old Jul 19, 2009 | 08:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Turkish 200 Blocks
How can i tell if i have a proper 200 Block or a Turkish one ?
Steve
Old Jul 19, 2009 | 08:48 PM
STUCOS's Avatar
STUCOS
They have 99 cast on block on drivers side,if i remember correctly,a lot of new blocks that came direct from cosworth,woodfords etc a few years ago were 99 blocks,but ment to be ok under 500 bhp
cheeRS stu
Old Jul 19, 2009 | 08:55 PM
I never knew that.
Old Jul 19, 2009 | 08:56 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
cheeRS stu
Well it wont be going near 500bhp LOL
Will dig it out and have a look tomorrow
Why do we play with these old cars
Steve
Old Jul 19, 2009 | 09:06 PM
Staffi's Avatar
Staffi
Steve, surely not?? you,re having some shit luck mate at the min......
Old Jul 19, 2009 | 09:12 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have had the car apart this week due to needing a helicoil and sorting out other underbonnet issues.
When putting the car back together today my brother and i noticed a small water stain under No3 exhaust port, looked in the head and you could also see some staining, also No3 on the exhaust manifold was white and the other 3 black.
Decided to take the head off and No3 piston had a nice pool of water and antifreeze sitting on top of it
Don't look like any damage to the gasket, the head has a few small cracks around the spark plug.
Might be the block but can't see anything
Steve
Old Jul 19, 2009 | 09:14 PM
Staffi's Avatar
Staffi
It,s that new found BOOSTTTT mate that,s done it...
Old Jul 19, 2009 | 09:16 PM
LHD220Turbo's Avatar
LHD220Turbo
as above; exhaust side of the block; number will look like this at the end 99
i think there is alot of people steer of these for the wrong reasons tho. i'd rather have a turkish block than a 205 block
Euan had one in his saff at 550hp, scooby slayer had one at 472bhp, i think Mad Ade has got one and his is 700hp
Matt
Old Jul 19, 2009 | 09:19 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Well i only have the 200 block so that's the one that will get used LOL
Steve
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You got yours back from Martin yet Pete ?
Steve
Old Jul 19, 2009 | 09:21 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Originally Posted by LHD220Turbo
iEuan had one in his saff at 550hp, scooby slayer had one at 472bhp, i think Mad Ade has got one and his is 700hp
Matt
Ade has run at circa 600bhp for over 12 months or so, hes hopeing its well heat cycled by now & can take the full 700bhp very soon.
Staffi's Avatar
Staffi
Steve
Steve,
Your block will be fine, turkish ones can cope with decent power anyway, just when heading to the silly heights of 800bhp + they struggle..
No mate, sometime this week...........
Old Jul 19, 2009 | 09:24 PM
LHD220Turbo
well he's just being greedy then! ha
having said that didnt Mad Yum's give up the ghost? or was that because of a liner problem? - cant remember
Old Jul 20, 2009 | 10:58 AM
MAD Ade's Avatar
MAD Ade
Both Rods and Daves were brand new blocks, and had not been through any heat cycles, so it's suspected that the blocks both flexed due to the mahoosive torque causing the liners to move.
Old Jul 20, 2009 | 11:48 AM
scoooby slayer's Avatar
scoooby slayer
mine was brand new and 100 % perfect and reliable 472 bhp but only 342 lbft. was just standard head bolts to.
Old Jul 20, 2009 | 12:12 PM
rossco22's Avatar
rossco22
How comes yours only made 342 lbft then m8 ? Or was there anouther issue.....
Old Jul 20, 2009 | 12:18 PM
lee2cossies's Avatar
lee2cossies
I have a new block but instead of the 99 it has 98 cast,does this make it a turkish block? I was told it was a belgium block?
Old Jul 20, 2009 | 12:37 PM
Garage19's Avatar
Garage19
I'm intersted in yours and Rods theory that the blocks get heat cycled.
From what i know of cast iron it needs to be elevated to temps way higher than 100 deg c to be normalized or hardened and any hardening that does occur is limited.
Old Jul 20, 2009 | 12:59 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Mine is also a 99 block. Should be ok. Standard head bolts still
Old Jul 20, 2009 | 01:44 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Aint any theory behind anything , Ade will find out if heat cycles & perlonged use make it last with 700bhp, if it dont he will require a new Block. Daves warped in the mid 600's & mine did the same at about 750bhp we know another Tuner has had the same probs at these levels. If we had any theory on these Blocks we would not have used the B****y things .
Old Jul 20, 2009 | 02:38 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Well my engine builder is on holiday all week
Wont be at Ford Fair now in the 4i
Steve
Old Jul 20, 2009 | 03:03 PM
costina's Avatar
costina
Live long and prosper!!
shit luck didnt you have a similar prob with the other block?????
Old Jul 20, 2009 | 03:08 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The other block was only a normal pinto one with cossie internals and lasted 9 years LOL
The one in the car now is a cossie 205 block and has lasted about 18 months
Oh well, dig out the 200 block and get that all built up.
Do i go for a higher spec though ?????
Steve
Old Jul 20, 2009 | 03:32 PM
CossieRich's Avatar
CossieRich
Of course you go for a higher spec steve. No point in using the 200 block and staying at the same power
Old Jul 20, 2009 | 03:35 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Chat Chip up to get me the same spec turbo as you then LOL
Steve
Old Jul 20, 2009 | 03:44 PM
CossieRich's Avatar
CossieRich
Chip ^^^^^
Old Jul 20, 2009 | 04:46 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Dug the block out, casting numbers are 24D91
Old Jul 20, 2009 | 05:25 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
At a guess that would be a 91 block then stevie boy, big power here it comes
Steve
Old Jul 20, 2009 | 06:08 PM
cossiedrift's Avatar
cossiedrift
whats the 98 then?
Old Jul 20, 2009 | 06:13 PM
Paul_RS's Avatar
Paul_RS
I've heard that the turkish block only fail due to liners?
I know someone getting a 640bhp engine built using a turkish block
Old Jul 20, 2009 | 06:24 PM
Staffi's Avatar
Staffi
Steve
Has to be Steve imo, now you have the block mate, seem a tad pointless not to as mentioned above..
Old Jul 20, 2009 | 06:40 PM
Its Dave's Avatar
Its Dave
Didn't use a Turkish block by choise, it was Ranj's engine that l bought and at that time no one knew about the problems.
Its ok now have a original old block
Old Jul 20, 2009 | 08:11 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Not true, they warp & head gaskets lets go. When measured the rear of my Block dropped away .004" but that was enough. Think Daves went in the middle but not sure.
The person getting that built is not sensible with the information that others are giving out, very expensive if that goes the same way.
Old Jul 20, 2009 | 08:24 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
so is the last 2 digits the year of casting then??
Old Jul 20, 2009 | 08:34 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Would be nice to know as my 205 block ends in 88
Steve
Old Jul 20, 2009 | 08:42 PM
Moonstone Steve.
I think so as my 205 block is a 88 and both my 200 blocks are stamped 91
Steve
Old Jul 20, 2009 | 11:04 PM
lee2cossies
Can anyone explain this 98 one i got then? last 2 digits are 98,i double checked earlier and definetly a 98.
Old Jul 20, 2009 | 11:10 PM
Kevin Sharp's Avatar
Kevin Sharp
whats a virgin EEC4 block worth while we are on the subject of blocks then?
Old Jul 21, 2009 | 12:35 AM
JonnyBravo's Avatar
JonnyBravo
£50 Kev... inc delivery and I'll take it.
Old Jul 21, 2009 | 07:13 AM
Kevin Sharp
LOL
Nov 1, 2015 06:53 PM
chowfornow
Alloy wheels and ICE for sale
15
Oct 17, 2015 07:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
