I/Coolers, Lag, max psi etc
Old Feb 29, 2004 | 05:09 PM
Default I/Coolers, Lag, max psi etc
Wats the max performance i can expect to get using a 4x4 I/cooler i currentl have a std 2wd item but hear there is a boost drop/lack of boost response on RS500 sized units if not running decently high PSI levels.
I want about 340bhp 26psi max with lagless boost from std compression will a 4x4 or 2wd item still handle temps? Will i notice the drop in boost using the bigger 500I/C. Is there something in between if so?
Old Mar 1, 2004 | 06:41 PM
I think I will swap for a 4x4 item and a max of 25psi? Thanks for all your input
Old Mar 1, 2004 | 06:45 PM
the original's Avatar
the original
i got 28psi on 4x4cooler the temps are fine.
Old Mar 1, 2004 | 07:08 PM
Cheers "the original", wats the best bhp/psi i can safely use my 2wd item upto? anybody got a 4x4 item for sale sensible price only thanks?
Old Mar 1, 2004 | 10:28 PM
the original
wat i would do "MrC" is invest in a secs monitor, then reset the peak held data, give your car some welly and see what the peak ACT is, if it's fine at a particular boost then no need to upgrade.....
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
dombanks
Sep 21, 2015 08:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
Marino
Sep 12, 2015 11:10 AM
