best place get a lambda sensor from?
Old Jul 5, 2009 | 05:58 PM
seans saff's Avatar
seans saff
Default best place get a lambda sensor from?
iv noticed today a wire (the red one) on my lambda sensor has broke from inside the sensor so need a new 1
its for my 4x4 k reg saph the sensor has got 3 wires red.black,and white
best place go for 1? and is it still ok to use the car?
cheers
Old Jul 5, 2009 | 06:23 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
got them in stock and it will be fine to use
Old Jul 5, 2009 | 06:27 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
depending on your software you may not even need one pal, is it a std car?
if its been tuned, speak to whoever wrote the software to check if its closed loop enabled or not.
Old Jul 5, 2009 | 06:30 PM
ickey818's Avatar
ickey818
I have one in good condition which you can have. I removed it from my 4x4 K plate saph when I changed to a 2wd exhaust manifold, I now have a Bosch sensor in the downpipe.
The original Ford lambda sensor was working fine when I removed it, the only thing is it doesn't have the original Ford plug so you would need to fit the one off your old sensor. Let me know if your interested and I can post it to you.
Old Jul 5, 2009 | 06:31 PM
seans saff's Avatar
seans saff
its stage 3, but i think the car is over fueling a lot as there is allways flames and fire balls coming from the exhaust so was wondering if this is part of my problem
Old Jul 5, 2009 | 06:33 PM
seans saff's Avatar
seans saff
how much do you want for it?
Old Jul 5, 2009 | 06:35 PM
seans saff's Avatar
seans saff
so if its closed loop enabled does that mean i wont need one? it had a new powerchips chip in it 3 months ago so can find out from the place i went easily enough
JTECH James
Passion for Fords!
speak to whoever wrote the software to check if its closed loop enabled or not pal, otherwise your wasting your money fitting a sensor
if its not closed loop enabled you have no need for the lambda sensor.
very few tuners do closed loop chips ie MSD,
your ppoor running could be a poorly set up car, bad map, etc
Old Jul 5, 2009 | 06:36 PM
seans saff's Avatar
seans saff
thanks for help will ring 2mo
Old Jul 5, 2009 | 06:40 PM
ickey818's Avatar
ickey818
You can have it mate, just pm your address and I'll post it to you. It's no good to me and has been sat in the garage for the last 2 years so if you can make use of it it's yours.
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
