'COSSIE RICH SPEC GT30' - GT3071 - 4" inlet - .82 backend - internal gate - 450bhp
GT3071 for sale.
Same spec as cossie rich's that made 453 on a set of DD rollers recently on a standard YB head with a BD14 inlet
Comes complete with:
Surge ported inlet housing
V band adaptor outlet
V band itself
The V band portion you need to weld onto your existing downpipe (3" needed)
Actuator (needs bracket sorting for how you orientate it, so you will need to do that)
£900 with fittings
i bought this from chip about 6 months ago but never used it. so its still brand new.
These are 1430 dollars in the states for a bare turbo currently from ATP
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Thats without the surge ported front housing, without the actuator and without the v aband adaptor outlet or fittings, that lot pushes it up to well over 1600 dollars, and then you have to get it here!
Brand new, genuine garrett
[IMG]file:///C:/Users/ACER_O%7E1/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
V band itself
£900 with fittings
but when i've been looking it might fasten up without cutting the exhaust as the exhaust is a simlar shape to the v band anyway. (i may be wrong)
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
