CAR WAS RUNNING ON 3 CYINDERS
Hi all,
yet another question.
My car over the weekend decided it was going to kill a plug. Put another plug in and all was fine for a day. it has now killed another plug and when i pulled it out is was wet though with petrol. It runs fine on all the other cylinders but seems to be running wrong on this one. Done a compression test and found it to be about 125 psi on all the cylinders. what could be wrong. Could it be the metering unit on its way out? has anyone else had this problem? also noticed that when I pulled the plug out after a long run it appears to be running too rich as it is black and sooty but all the other cylinders and a nie brown colour.
Hope someone can help as its so close to being reliable now.
Dave
Dave
mine was running on 3 cyinders
but that was caus it was running on water!!
due 2 my head gasket goin tits up
but before i knew it was running on water it was killing plugs once a week, they were jet black when i removed them ( this is only cylinder 3 ) so it MITE be head gasket but dont quote me on that. could be ur metering head tho.
sorry this hasnt realy helped lol
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
