205 block problems!
I've just done the headgasket on my 2wd saph, when i cleaned the block face up i noticed a very faint line from a bolt hole out to the water jackets. The car was running fine before i took it off, its not been studed, and the new bolts have all torqued up ok! Hopefully have it running sunday, but am i wasting my time finishing it off? Its been in garage for 18 mounths having underbody resto and cant face having to break it
yeah serious, it's from my old engine that the big ends died and it's just sat around doing nothing since, i've also pretty much got rid of most of my cossie so i'd rather someone make some use of it !
i am located in Sutton Surrey
Have done a headgasket on a 205 block, and most recently done another as part of an engine rebuild.
Didn't notice any 'lines'. It's hard to determine what you mean by 'line'. Is it a physical groove, or just a mark/discolouration?
It's a bit late now, but ideally you could have re-surfaced the block (known as 'decking') which would hopefully clear up any 'lines'.
Or, a crack test, or at least get it inspected by someone who knows what to look for.
I really hope that it was nothing more than a bit of deopsited carbon and that your car runs like a dream. Cossies can test patience
thanks guts the mrs is going to go tits if its fucked!! Tabs its not cracked in the threads just a line across the top to the jackets! I rubbed my finger over the area and couldn't feel anything and as said before it torqued down ok.
Fingers crossed time i think
Check out NDT (Non Destructive Testing) companies or suppliers near you maybe Ian?
try rocol flawfinder you can find it on flebay or in any good enginnering shop its a 3 can system works well and shows up any cracks
can 1 Flawfinder Safety Cleaner
Prepares surfaces prior to testing
Removes contaminants, oil, grease, dirt, excess penetrant
Safe on metals and some plastics
can 2 Flawfinder Dye Penetrant
High definition red dye indicates surface cracks and flaws in normal light
Water washable
can 3 Flawfinder Developer
White film which highlights penetrant dyes
Excellent background for viewing
Water washable
hope this helps
dooge
Water washable
Water washable
hope this helps
dooge
Water washable
Water washable
hope this helps
dooge
Water washable
Water washable
hope this helps
dooge
Ian
it runs, well it did! smokes a bit but think that was down to me pouring some oil in the bores, then waterpump started leaking which is strange cos it didnt before. Then it cut out i wipped the plugs out and they were wet so will try again tomorrow,
fingers crossed
fingers crossed
My pump leaked after its lay up - flippin annoying. If you get a new one check before you fit. Mine from Woodford - a gen Ford mind you - wasn't drilled out in the inlet and I only found out after fitting it and overheating!!
timsrs
22
Sep 24, 2015 08:14 PM
Andypandy260
Sep 23, 2015 10:28 PM
