rev counter for coil pack
Old Jun 21, 2009 | 10:29 PM
johnyjn's Avatar
johnyjn
Default rev counter for coil pack
Can't remember the way to convert a standard rev counter to read the coil pack ?
Old Jun 22, 2009 | 05:51 AM
All I did was use a plug in module, between ecu and tach, £30 job done, been 100% perfect ever since.
Old Jun 22, 2009 | 06:00 AM
Stu @ M Developments's Avatar
PassionFords Creator
Do you have details you can post up Tabs?
Failing that, I can supply you a diagram on how to wire it yourself, but a doubler module sounds potentiall simpler.
Old Jun 22, 2009 | 07:36 PM
cossiegreg1's Avatar
cossiegreg1
would like to know this cos i fancy coil packs, just was unsure about rev counter
Old Jun 23, 2009 | 05:05 PM
johnyjn's Avatar
johnyjn
Any contact numbers for this item tabetha ? Many thanks
Old Jun 23, 2009 | 05:15 PM
KSA-Cossie's Avatar
KSA-Cossie
I've got a stack st200 tacho.
Old Jun 23, 2009 | 06:08 PM
I just bought a unit from Emerald, goes between tacho and coilpack, to do the convertery bit, sure I'm still using coil feed to tacho not the ecu(aftermarket) feed, will ask me loom na tonight and post up and pm stu, when more info.
Old Jun 23, 2009 | 08:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
The diagram Stu supplied to me after fitting the coil pack works fine on my car.
Steve
Old Jun 23, 2009 | 11:00 PM
johnyjn's Avatar
johnyjn
Steve
Any pics ??????
Old Jun 24, 2009 | 01:22 PM
rs2klee's Avatar
rs2klee
K***LMT
Old Jun 24, 2009 | 02:08 PM
Haven't seen dave yet, as someone(off here!!) is late for mapping, so think dave's sunbathing, but going down in a bit and will ask.
Old Jun 24, 2009 | 04:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve
Originally Posted by johnyjn
Any pics ??????
Sorry, the diagram got binned after fitting.
Steve
Old Jun 24, 2009 | 05:04 PM
s1cab's Avatar
s1cab
ive got this problem on mine. was told that if i fit inj clocks it will work? anyone confirm this?...
Old Jun 24, 2009 | 05:10 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
its a very simple mod on the 4x4s
Old Jun 24, 2009 | 07:29 PM
johnyjn's Avatar
johnyjn
My car is running a pectel t2 ecu do they have a signal feed coming out for a rev counter ?
Old Jul 2, 2009 | 09:58 PM
johnyjn's Avatar
johnyjn
Old Jul 15, 2009 | 10:00 PM
rich123's Avatar
rich123
hay up john can u not run it off the tack wire that would usualy go your coil as it would still use the tach wire for wiring up the coil pack? thats all ive done with mine and works perfect on a grp a coil?
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
