Operation Spike Shield
Old Jun 16, 2009 | 11:23 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default Operation Spike Shield
A little while after moving into my house I instigated "Operation Spike Shield" to upgrade the perimeter security incase someone should try and break in.
Over the weekend i heard my garage door silent alarm go off so as per my plans I armed myself prior to checking out the rear windows that oversee the garage. As i did so i heard a scream and saw what appeared to be a couple of CHAV's running off to the rear and down the side alley...
Further investigation revealed that no access had been gained on my garage (my alarm is deliberately sensitive so i know how often people try the door etc) but damage was found on my "spike shield" defence system which had successfully repulsed the attack but did suffer some collateral damage.
You can clearly see the damage here where theyve tried to climb over the gate:
Hopefully they are in serious pain as a result!!
It was quickly repaired:
More worryingly, in the morning i found damage to my front door frame where they have tried to force the door with a crowbar or similar:
Obviously being a modern door with steel reinforced frame it held fine (im sure youve all seen police programs and the high amount of strikes needed with the "big red key"). So it seems theyve tried a two pronged attack.
So this leaves me with a dilema.... Obviously from being unable to open front door they will know that its a modern high security UPVC door rather than the earlier single lock ones. So the next step is for them to return with tools to take down a modern door in the near future. But i cant think of anything to do to reinforce the door and frame it self unless i have it lined with steel sheet on the inside. Oviously that is a bit excessive.....
So what should be the next step to keep ahead of them?? Obviously i need to raise the stakes to match and preferably beat the threat.
Old Jun 16, 2009 | 11:26 PM
Physio's Avatar
Physio
Oh I dont know, mines in the ground perhaps?
Old Jun 16, 2009 | 11:38 PM
Hank Moody's Avatar
Hank Moody
some of my personal favourites here
http://www.diggerhistory.info/pages-weapons/mines06.htm
Old Jun 16, 2009 | 11:44 PM
swebber23's Avatar
swebber23
Stick a massive bit of wood like a fence post wedged against the door like the dealers have on all police tv programs
Old Jun 16, 2009 | 11:46 PM
Hank Moody's Avatar
Hank Moody
wire the door up to a truck battery, nice little fright for the chav with the crowbar
Psycho Warren
Carbon Crazy
the woods a good idea!!
The rest need to be realistic they are obviously serious about getting in to attack the front door as its not a quiet road and is a main throughfare for pedestrians at all hours.
Old Jun 16, 2009 | 11:49 PM
swebber23's Avatar
swebber23
Why do they actually want to get in? Are you sure it is not just scallys mucking about?
Old Jun 16, 2009 | 11:50 PM
xr4x4rs's Avatar
xr4x4rs
have a steel door behind your front door concreted in, so no matter if they get into the front door they will think fuk it after seeing the 2nd door
Old Jun 16, 2009 | 11:52 PM
orionmojo's Avatar
orionmojo
A cattle fence.
it gives you a big wake up call anyways. i found out when i touched one in ireland
if you spend ore you can get ones with adjustable voltage
If you mount one just below the top of your fence you can have strands of wire coming off it (think like cb aerials, the way they move) and you cant even grab them then to push them out of the way. inpenetrable electric fence
Old Jun 17, 2009 | 12:02 AM
swebber23's Avatar
swebber23
He only needs one voltage... KILL
Old Jun 17, 2009 | 12:16 AM
dreamer's Avatar
dreamer
Are they lookin for the car keys
Seen your Puma maybe and want it
Police an option? Ya might be stabbed in your bed next time
Dealer-ish security door is a stop gap cos unless the local police know ya and why you have it cos otherwise you'll be under surveillance as a dealer before you know it
And there's still windows in the house..sounds like your fairly vulnerable..but aren't you ex services?? Few big mates hangin round could work wonders
buy a proper pellet/BB gun and make a show of testing it outside your door maybe?
I don't know but I'll tell you this you've probably seen the cunts regularly that done that to your door-You'll have to do something
Old Jun 17, 2009 | 12:19 AM
boothy's Avatar
boothy
Yeh why is the house so attractive to thieves? do they know about your car....
Old Jun 17, 2009 | 12:35 AM
Fezza's Avatar
Fezza
H71 CNX
Be aware, if the chavvy buggers who were trying it on decide to sue you, they would be within their 'rights'
If you put spikes, electrical wires or barbed wire on property in a position where it potentially could harm someone (even though they deserve it and shouldnt have been climbing your fence) you should display the appropriate warning sign.
I got this advice from a solicitor mate when I was looking at putting spike strips and electrical fencing along the edge of my fence after having stuff nicked from the garden.
Old Jun 17, 2009 | 12:36 AM
Psycho Warren
Carbon Crazy
My car I suspect!! scallys mucking around dont crow bar a front door climbing fences fair enough
Probably keys as you say. Ive tried reporting such suspicious activity before and theres no follow up. Once they sent a cop car around about an hour later Nothing they can do anyway! not like they are going to watch my house!!
Surveillance would be good No one could break in then!!
Its typical modern double glazing.. bricking up the windows is not realistic really for a house I dont have loads of big mates living local who i can have hanging around!! Yes im ex-forces but its not like ive got a personal arsenal of assault rifles hanging round, or claymore mines etc!!
And get rapidly arrested as armed response come along following reports of an armed man in the street Plus BB guns are plastic toys which wont deter criminals!! BB guns only seem to scare the ignorant public.
Only real guns scare criminals as the bullets fly past thier head. anyone can wave a gun about. That dont scare anyone these days unless theres real bullets and thats not realistic as a civilian here
Im trying to avoid going on a anti-criminal rampage in my local community as i have to live here. Unfortunately i can no longer go on rampage then go back to the security of Base behind barbed wire fences and armed guards....
Old Jun 17, 2009 | 12:39 AM
Psycho Warren
Carbon Crazy
its a pretty unique car for the area so easily recognisable, plus with the job centre one street away, the area is full of skanky criminal scum all day long probably scoping the area while they wait for signing on time! So its highly likely someone in the criminal world will have seen me returning home/leaving home one day as theres no secret back routes to my house.
plus the house used to be a dealers houses before the previous tenants got evicted and i bought the place so its probably a known address to most the scumbags so theyll maybe be interested to know who now lives there, what they got etc.
Old Jun 17, 2009 | 12:40 AM
swebber23's Avatar
swebber23
Is the car kept in a garage at your house? Might be worth moving it and storing it at a mates for a couple of weeks? Providing the garage doesn't give access to your house and there is nothing worse nicking in it you could leave it open.... They may think you have got rid of the car and lose interest.
Old Jun 17, 2009 | 12:47 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I think you are enjoying the battle and would be bored if they fucked off totally
Old Jun 17, 2009 | 12:49 AM
Psycho Warren
Carbon Crazy
The garage is pretty secure with multiple locks and alarm sensors and certain other "security measures" plus my car is broken down at moment If im not in the car and out the house i have keys and ECU with me and its not possible to get a tow truck to my garage let alone tow it on full lock down the very narrow passageway on lock without totally destroying it in the process!
I doubt even a transit recovery with a speclift could get down this alley:
So theyd have to strip it of parts in situ.
Old Jun 17, 2009 | 12:51 AM
dreamer's Avatar
dreamer
Rough goings on
Is the car worth it!!!!
I like to be able to relax at night
Old Jun 17, 2009 | 12:53 AM
Psycho Warren
Carbon Crazy
Im not enjoying the battle as my property and possessions are at risk of being stolen!!!
As i said, if i was still living on base then i would have no problem with declaring my own personal crusade against the local criminal scum as i would have the safety of my secure base to return to every night whereas i have to live here so i dont want to be targetted by the scum bags yet i need to protect my possessions so i need to find a middle ground.
Old Jun 17, 2009 | 12:54 AM
Psycho Warren
Carbon Crazy
Rough goings on
why should i sell a car i spent 10 years working to get just because some pikey scum cunt faces cant leave other peoples possessions alone???
Old Jun 17, 2009 | 01:03 AM
Elvis's Avatar
Elvis
Hunka Hunka Burning Love
warren, msn mate.
Old Jun 17, 2009 | 01:06 AM
burnzy's Avatar
burnzy
burnzy
sorry to be a bit off topic but was it you or benni getting the stuff put in the passageway to your garage if it was you did you get too the bottom of it or could this be the same people after your car?
Old Jun 17, 2009 | 01:09 AM
Psycho Warren
Carbon Crazy
the stuff stopped getting put in passage way after a couple of weeks so i figured it was bored kids etc. Just fly tipping, drug addicts shooting up, drunks pissing etc these days
dreamer's Avatar
dreamer
I see your point-I've looked at a few pics of the car and it looks awesome BUT is it worth having your keys taken from INSIDE your house?
FWIW I doubt its local chavvy cunts messing with your house(ie wedging your door) I'd put money on it being professional thieves who know what your Puma/parts value is
I'm not havin a dig at you thats just my opinion.
Old Jun 17, 2009 | 01:16 AM
Psycho Warren
Carbon Crazy
the keys are on me whenever i leave house and not kept with me when in house so the ony way they can get keys is through robbery.
Old Jun 17, 2009 | 01:26 AM
dreamer's Avatar
dreamer
Well I hope it works out ok for ya-I couldn't sleep at night if i thought there was a chance there was some cunt intent on coming into my house for keys or whatever
Old Jun 17, 2009 | 01:28 AM
burnzy's Avatar
burnzy
burnzy
you've got nothing to worry about then
serious note sorry to hear it's such a state round your way, unfortunately we can't all have it our own way, atleast you've got your secure garage to keep you car safe
Old Jun 17, 2009 | 02:19 AM
Psycho Warren
Carbon Crazy
how do you sleep then?? no matter where you live these days the risk of home invasions for keys is increasing rapidly. doesnt matter if its a posh area.
I dont think its unreasonable to be able to live reasonably safe in the knowledge you wont be burgled or if you do its a rare thing!! When i lived in london i was burgled 3 times in 8 months and while here had my old car broke into twice in 3 months. In my opinion thats excessive amount of crime, especially considering the local cops crime statistics for my nieghbourhood are low for car crime and burglary and show peaks mostly for antisocial behaviour.
Old Jun 17, 2009 | 09:24 PM
kosman's Avatar
kosman
sideways all the way!
wire your front door and garage door to the mains that will teach the mofos
Old Jun 17, 2009 | 09:31 PM
Fast Guy's Avatar
Fast Guy
Replace the drawing pins with razor blades, then take the blood soaked blades to the police for dna testing.
Old Jun 17, 2009 | 09:33 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
just a little tip bus instead of loads of spikes etc try carpet grippe rod,it tears ye finger ends etc like a bastard and is easier to fit and remove as required
i know it hurts as from time to time working in houses i forget its there and come a cropper
good luck with the scummy twats fella
Old Jun 17, 2009 | 10:10 PM
G950KDT's Avatar
G950KDT
with regards to BB/Airsoft...... i nearly got arrested after a neighbour seen me lift a Ł1300 airsoft sniper rifle i was keeping for a mate in my lockup for the week while he was on holiday and builders were working on the house..... she was about to phone the rozzers on me until i explained that:
1) i have a firearms licence to permit having a gun
2) its for airsoft which i take part in
3) the working parts and battery were not there
4) she shouldnt be looking into my garage every hour of the fooking day when i go over, like she has for the past 5 months since moving in there!
Old Jun 17, 2009 | 10:43 PM
madsi's Avatar
madsi
baby moniters are a cheap way of listening out for peaple at the having a go doors,also the metal dog or animal cage doors work well fixed into the wall behind the main doors.the cops trying to get in a mate of mines house were scratching their heads for ages.
Old Jun 17, 2009 | 11:15 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
bloke i know is into all this sort of stuff like shotgun cartridges on his shed door thatgo off if you try it on and trip wire and the obligatory cctv.
he is a gun dealer too and has the old bill come round regularly for inspections and stuff. they arn't too happy with his collection of japanese swords either.
the best one he told me about was the neat square hole in the ground with broken bottles,sauce jars,and very sharp glass in that he knows where it is but thevin twat doesn't,he has heard someone go down it at night screaming and bleeding with claret all over the place.
he lives on a estate where people have very nice front gardens and stuff and noticed some cunt was robbin his flowers so set a trap,few weeks go by and he hears some fucker screaming again and they have cut themselves on his flower and bush security device
Old Jun 18, 2009 | 12:05 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
You want barbed fishing hooks, they won't be able to escape then, they will be stuck on the wall, with the option of staying there until you come to get them down with the aid of a blowtorch and nail gun, or rip themselves to pieces pulling out the barbs .... For added effect cover them with an arsnic/lead based paint
Old Jun 18, 2009 | 12:24 AM
BigJim19's Avatar
BigJim19
COS i'm WORTH it
for the house warren, you want a pair of dobermans, proper guard dogs, my mates boss has 2, doesn't even lock his house when they are in, they've seen off anyone thats not welcome, plus if you are in, they will hear anything before you will, so they will get you up if anything is wrong.
and get some cctv up, and wire it in to a hard drive recorder, easy to maintain then instead of swapping tapes all the time, then at least you can see who it is and pass it on to plod as evidence
Old Jun 18, 2009 | 01:36 AM
Psycho Warren
Carbon Crazy
problem with massive glass filled pits in ground is id have to drill through concrete to lay it and thats definitley classed as laying booby traps as its within the perimiter rather than perimiter protection.
Dogs arent practical for the size of the house really. plus im not a fan of dogs wouldnt want to come home one day and the dogs decided hes boss now!!!
Wont CCTV attract more attention?? plus these days you cant have covert CCTV legally and are required to put up those fucking gay homo data protection signs!!!
Old Jun 18, 2009 | 09:13 AM
Phil's Avatar
Phil
Jeebus
How about one of the security posts that folds into the floor inside the garage so they can't get the car out but can't see it from the outside either to attract attention. And also, one inside the house behind the front door will stop it opening!
Old Jun 18, 2009 | 10:33 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
I say good luck to any cunt who actually gets in because if you dont get them on the stairs with the Home Alone stylee paint pot swinging then you'll probably drop a home made atomic bomb on them
