vids of rb26dett engine noise :(
Old Jun 13, 2009 | 12:55 PM
scoooby slayer's Avatar
scoooby slayer
Default vids of rb26dett engine noise :(
when i get the little rattle cat overheat light flashes on then off and power fc is seeing a bit of knock free revving engine. have seen peak of 101 on knock gauge while driving it but dont know where as couldnt look til i pulled over. can be more specific tmrw when my mate is here with me.
Old Jun 13, 2009 | 02:04 PM
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
have you tried posting on gtr.co.uk mate ? they might be better helping you out
Old Jun 13, 2009 | 02:28 PM
scoooby slayer
thanks mate just joined and posted on there
Old Jun 13, 2009 | 02:38 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
its hard to help with videos...
Does make me wanna go and buy another though
They are awesome.
Old Jun 13, 2009 | 06:34 PM
scoooby slayer
i know vids are shit but any ideas ?
Old Jun 13, 2009 | 06:41 PM
AlexF's Avatar
AlexF
whast the oil pressure cold and hot at idle and at 3k?
Old Jun 13, 2009 | 07:23 PM
scoooby slayer
4 bar cold idle, 2 bar hot idle, 3 bar hot 4k revs, 2.5 bar hot 3k revs.
Old Jun 13, 2009 | 07:40 PM
Fagin's Avatar
Fagin
3bar hot @ 4k revs
My scoob is hitting 6bar @ those revs hot.
Old Jun 13, 2009 | 08:04 PM
scoooby slayer
Originally Posted by Fagin
3bar hot @ 4k revs
i think im gonna drop the lump out and take the sump off and have a look at the big ends. shells are only Ł100 for acl race series. crank grind about Ł300 if necasarry and maybe a rod if bearing has spun in it. i suppose it could be very early signs of a failure.
Old Jun 13, 2009 | 08:36 PM
bigal1978's Avatar
bigal1978
think u got a dud i got 3 k here for it
Old Jun 13, 2009 | 08:37 PM
Turner RS's Avatar
Turner RS
I have looked at your threads with interest on this car, you were told the bottom end is on its way out, they are correct.
Old Jun 13, 2009 | 08:55 PM
scoooby slayer
she aint no dud. must be very early signs so aint gonna be much wrong in there. i will know for sure tmrw. a genuine 535 bhp r32 has gotta be worth 10k so i cant loose really. i shall ring rob monday aswell and see what he would charge.
Old Jun 13, 2009 | 09:41 PM
Ebonycossie4x4
Not 10K anymore....
It does not matter mate, it will be awesome when finished. You never get back what you put in with modified cars anyway.
Im glad you have now realised that its definately a problem that requires a strip down, Its happened to me in the past and ive always wanted to not beleive the people telling me and thats why i didnt say anything earlier.
Dont buy another engine rebuild youres, you have caught it early so wont be too much damage, they are awesome cars, just get with one reputable tuner and stick with him, Rob is awesome but i stilll like ron and would always recommend him, then id get rob to map it.
Good luck mate its a long and often expensive road...
when you get power hungry with these though its mega!!!
Old Jun 13, 2009 | 09:48 PM
scoooby slayer
Originally Posted by Ebonycossie4x4
Not 10K anymore....
must be very early signs mate if it is as there is no apparant knock compared to what i know as knock when the crank is fubar. i reckon i could do it myself for Ł1k ive checked on prices of parts. but if rob will do it for around Ł3k he will get the job i think. at the worst a crank grind and 1 rod id of thought. il be happy staying at 1.5 bar for 535 bhp. it will still be cheap at 7 - 8k with a freshened up engine. cheapest 550 bhp r32 i could find was 10k maybe im looking in the wrong places ?
at least its already got all the bits to run the power.
Old Jun 13, 2009 | 09:58 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
its very hard to say from the vids tbh, but id guess at it being an early big end rumble, as you said from where you are now, get the sump off and inspect it would be the best way forward, maybe renew the oil pump while your in there aswell
Old Jun 13, 2009 | 10:03 PM
scoooby slayer
i suppose it wouldnt hurt and if im not happy could still take the lump straight to rob. i need some superman xray vision so i can look in there easily
Old Jun 13, 2009 | 10:09 PM
JTECH James
Passion for Fords!
if it is that, its not to bad really, an easy thing to fix..
but if its not you could end up putting it back together the samer as it is now lol,
so do lots of diagnostic work before you strip it, to make sure you know what it is first imo, maybe let someone who sees these every day take a look and listen
Old Jun 13, 2009 | 10:20 PM
scoooby slayer
im gonna have a more in depth look tmrw with my mate. will then see exactly at what points its getting massive knock on the power fc monitor.
Old Jun 13, 2009 | 10:23 PM
scoooby slayer
one thing that is baffling is that on idle the knock readout is 0. you would think it would pick up vibration all the time on a big end ?
Old Jun 13, 2009 | 10:25 PM
JTECH James
Passion for Fords!
ive normally noticed big ends as you pick up the revs, not when they are held at a set rpm so much
Old Jun 13, 2009 | 10:34 PM
scoooby slayer
open the throttle sounds perfect, i remember an old cvh orion i had and number 2 let go and that knocked harder and harder as the revs rose higher. and a cat engine just the same the noise didnt just go away. i gave it a little rag earlier and hit 7200 rpm twice and it was fine ! possibly oil pump related, pressure is down a bit, but i cant see how the pump could make that noise.
Old Jun 13, 2009 | 10:38 PM
JTECH James
Passion for Fords!
does it run variable valve timing? and if so it it oil pressure related? maybe another thing to look at
Old Jun 13, 2009 | 10:54 PM
polly_x's Avatar
polly_x
Why dont you stop guessing and posting videos on the internet and just take it someone who knows Skylines??? Perhaps the guy who mapped it if he knows it so well?
I am guessing it was sold for 4K for a reason? Assuming it was the person that had it modified sounds like they got out of it because they knew what was wrong and needed doing and the likely cost??
Awesome cars though. Had one about 10 years ago and loved it. Hope you get it sorted.
Old Jun 14, 2009 | 07:14 AM
scoooby slayer
just asking peoples views as theres quite a few knowledgable people on here. it was sold for Ł4k beacause the guy needed the cash quick and was worried about what was causing the noise.
if youve got nothing constructive to say dont post !
Old Jun 14, 2009 | 07:29 AM
wirralphil's Avatar
wirralphil
He is being constructive He's saying take it to a person who knows these engines inside out instead of asking online.
Old Jun 14, 2009 | 07:39 AM
scoooby slayer
some things will seem worrying and turn out to be something silly. sometimes they wont. ive already had 3 professional opinions on it and there not the same answer, but if i voice them on here people are inclined to just agree with that.
im not worried in the slightest but ive been caught before with heavy machinery when its stripped to bits and then you wish you had done more tests before hand. too late once its stripped to bits mate.
im a mechanic by trade on big cat machinery and ive done a couple of petrol engines. ive heard engines with a variation of problems knocking, cracked pistons, camwear etc. but this noise i have i cant put my finger on it ? you can soon spend Ł4k on a Ł1k job you see.
Old Jun 14, 2009 | 07:55 AM
JohnnyB's Avatar
JohnnyB
if you have fucked BIG END's the oil pressure will be low even if the pump is working well.
Old Jun 14, 2009 | 07:59 AM
scoooby slayer
my thoughts exactly you wouldnt expect to see 2 bar hot idle ?
Old Jun 14, 2009 | 08:00 AM
coswurv's Avatar
coswurv
Ł300 fort a crank grind, i had my cossie one done for Ł50 just on the big end journals.
Old Jun 14, 2009 | 08:16 AM
polly_x's Avatar
polly_x
Just what I was thinking. Mine is probably the most sensible and constructive post on here IMO!!
Just take it to someone who knows these engines mate. Chances are it will be diagnosed in 2 minutes properly. Fairly sure one of the big Skyliner tuners would have heard a knocking bottom end before on one so will give you an answer.
Personally I would be doing that 10 times before even thinking about dropping engines out or taking the sump off etc.
Like I said. Hope you get it sorted.
EDIT: Just seen you have taken it 3 places already and had 3 differing opinions. Thats a bit more worrying I guess.
Old Jun 14, 2009 | 09:35 AM
AlexF's Avatar
AlexF
I know what you mean about not wanting to throw money at a problem untill you know what it is...
Sad with bearings you cant find out with out striipping it down easily...
But there is one more route you can try, oil analysis.
There are a few places that can analyse oil for any metal contamination (bearing material is easy to spot).
Alex
Old Jun 14, 2009 | 04:50 PM
scoooby slayer
well me and mate had a look today. deffinateley something coming from sump but very quiet and only now and then. gonna get a price of rob tweenie tmrw for a freshen up and go from there.
Old Jun 14, 2009 | 05:20 PM
AlexF's Avatar
AlexF
DIY it
Old Jun 14, 2009 | 05:39 PM
silky16v's Avatar
silky16v
Get on That!
was out in my mate R33 GTR last night and his 100% defo runs 7 bar oil pressure when cold
2.5bar oil pressure @hot idle and soon as you rev it 4bar+ all the way up the rev range
Old Jun 14, 2009 | 07:12 PM
scoooby slayer
DIY it
may well do mate. its so quiet theres a good chance crank isnt even damaged.
Old Jun 14, 2009 | 07:13 PM
scoooby slayer
im not miles off then at 2 bar idle and 3 bar revving. hopefully not to much damage in there
Old Jun 14, 2009 | 08:37 PM
AlexF's Avatar
AlexF
That exactly what I get in my r33gtst
Stop driving it - rip the engine out - job done
Its gonna be a cracking car.
malkiemac3579
Jul 14, 2017 12:10 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
