What torque in NM?
Old Jun 13, 2009 | 09:35 AM
Cossy Mike's Avatar
Cossy Mike
Default What torque in NM?
Does anyone know what torque the bottom pulley bolt should be when I put it back on after changing my timing belt?
It's a Sapphire Cosworth 4x4 1991 (J Red top YB)
Thanks!
Old Jun 13, 2009 | 12:55 PM
122-135NM
Old Jun 13, 2009 | 04:49 PM
Cossy Mike's Avatar
Cossy Mike
Job done
Had to go out and buy a 230v Impact wrench to shift the pulley bolt!
Pulley itself came off no bother. The belt took about 2.5 hours to do, thats including draining the coolant off, dropping radiator, underbody tray, timing belt cover and new tensioner.
The belts Ford supllied me with for the Alternator were to small so only good for Power steering.
I had to put the old belts back on and ones cracking and missing a tooth
Best get to Halfords soon
Old Jun 13, 2009 | 08:13 PM
davy 6457's Avatar
davy 6457
why you drain the coolant out and drop the rad? last time i done a belt on mine it took about 45mins tops!
Old Jun 14, 2009 | 07:56 AM
Cossy Mike's Avatar
Cossy Mike
There is only about 20mm clearance from the radiator to the bottom pulley bolt + I needed to get a 3 legged puller on the pulley. No way I could have done it with the radiator on.
Old Jun 14, 2009 | 08:31 AM
Be VERY careful when using a puller on these, the thing you should have done with the pulley off is to take out the woodruff key and apply valve lapping paste to crank nose and lap a bit, this would mean no more getting stuck, my pulley can be slid off with just moderate hand pressure.
That way in future just remove fans, and can do it all easier no coolant issues.
Nov 1, 2015 06:53 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
