average price or a proper rolling road set-up?
what sort of price is the usual for a good set-up on rolling road, inlcuding tweaking timing via vernier pulley, and mapping etc. might be cheaper to pull engine out and get it dyno'd from what i've heard so far!" p.s its a mk4 escort 2.0 n/a ZVH
I'd imagine if its done properly most places would charge similar to a live map? Although ultimately i'd expect it to be done much quicker on a RR than on the road so maybe could be cheaper.
I would have to say anywhere from Ł300-Ł500 for a full remap would be reasonable.
If its just a setup with a few tweaks to timing then should be a lot less.
Not being funny but Ł300 is not exactly a lot these days, when you consider the cost of RR to buy , and the operators time etc, and it's most likely cheaper, than pistons without holes in a few mile down road.
You would if that is what they charged and you needed it!!
Obviously if it was on carbs etc then the price changes accordingly
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
