Heated Front Windscreen
Old Jun 7, 2009 | 08:30 AM
Dan_L's Avatar
Dan_L
Default Heated Front Windscreen
Hi,
On my focus there is a button to turn on my heated front windscreen but on my girlfriends fiesta that is a bit newer she has the checked thing in the top of the windscreen but no button.
On newer Fords is it automatic that the heated front screen comes on when it gets steemed up?
Thanks,
Dany
Old Jun 7, 2009 | 08:41 AM
focusv8's Avatar
focusv8
The "Checked thing" isn't the heater.
Old Jun 7, 2009 | 08:56 AM
Dan_L's Avatar
Dan_L
Ah right is it the aerial? Do not all new Fords comd with a heated front screen then?
Old Jun 7, 2009 | 09:01 AM
neil andeRSon's Avatar
neil andeRSon
don't think it. easiest way to check is to look at the glass. there'll be load's of tiny wavey lines through it if it's heated.
Old Jun 7, 2009 | 09:16 AM
The other way you'll know is when it comes new screen time, they're a lot more expensive!!
But as said wavy lines in screen easiest clue.
Bailes1992
Sep 3, 2015 02:17 PM
StephTell
Sep 2, 2015 06:31 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
