ford puma lowerd 60mm
i have been looking for 60mm springs for my puma but cant find any anywere all i can find is 40mm the only other thing is coilovers but that will be a last resort will fiesta springs fit ?
I've only ever seen the likes of Eibach that go -40mm. As you say, coilovers are the best way to get 60mm low. With a drop of that much, you'll probably need to cut the inner front arch away at the top (the same as how FRP's are) otherwise you'll rub. Especially if you're running 17" wheels (7" wide) You'll also get inner tyre wear as there is no adjustable camber on a Puma unless you get adjustable lower arms.
Ben26
Aug 27, 2015 08:56 PM
borboyous
Aug 22, 2015 11:17 AM
