Missfire
Hi all I have just developed a intermittent missfire when I come on boost in the 3 door
Some times its there sometimes it aint
I dont know where to start but at the same time my fuel pump now primes for bang on
14 seconds if the engine is of and earlier it cut out completely
the fuel pump cut out and wouldnt make any noise
I fiddled with the wires nothing opened the bonnet ,didnt touch any thing
turned the ign on the fuel pump primed for bang on 14 secs then I started as normal
Its all got to be linked
Oh and when it misses it stinks of petrol
Where do I start
Opened up the dizzy and the arm is a red 1 I thought they were black
Where do I start
I'm going with plugs too.
Your pump doesn't always need to prime for 14 seconds - if the fuel system is up to pressure it only primes for a fraction of a second.
The plugs are gonna get changed in a minute and the phase looks good
What shall I gap plugs too champions
The pumpkeeps priming for bang on 14 secs thats what I dont understand
Been through it today changed the plugs it was fine
But now its even worse
https://passionford.com/forum/ford-s...ct-sensor.html
Right it looks like the ect sensor has gone
and now all the checking of the phase has screwed that today all the plastic has gone
and the wires are all corroded and fraying apart could this be the cause of all my problems
Trial and error with something like a missfire though mate. And at least at the end of it if you have changed a few bits you know they are new and shouldnt give you any further problems for a while.
If you put new plugs in at 20thou and its still the same, change phase sensor, if still the same change the crank sensor (you could try taking it off and just cleaning the end of it with a rag first rather than replacing it, because they do get oily etc)
Right changed the ECT and phase sensor it idles and revs fine
But drives the same pops bangs misses and shoots flames out the back but will run bit better with the brown plug disconected ACT.
Whats next guys
Whats next guys
if it runs better with the act unplugged could that be the fault ie, giving a false reading to the ecu but when no reading at all it will go to a base setting.
Could be wrong as its just a guess.
No secs mate and the loom is orig
Its defo got to be a sensor with all the heat
Gonna change everything this week and see if that cures it if not whos best to take it to
I live in bristol (dont say Interpro) ive gotmy reasons why (dont like being ripped off)
It only does it on boost doesnt matter if I nail it or ease it wont go past 3.5k
Gonna try a map tonight hopefully
If still no good gonna take it to Interpro see what they say
Ginge !
23
May 28, 2005 01:06 PM
