judder after rebuild..??
Old May 27, 2009 | 09:40 PM
an1mal_69's Avatar
an1mal_69
Default judder after rebuild..??
Jus been for a little run an ive got a judder at speed. Ive had the rear beam off and fitted polybushes, did have a slight judder thru the gearstick before i pulled it in bits, d'ya rekon its jus been amplified by the stiffer set-up..??
Does the diff' need aligning at all, it did go back as it came out..or could it be the do-nut washer in the centre of the shaft..??
Old May 28, 2009 | 05:49 AM
The poly bushes do amplify and out of balance, did so terribly on me xr4i, but might be worth trying prop round 1 bolt hole till you get the smoothest, can't see why myself, but some say it works.
Old May 28, 2009 | 10:56 AM
an1mal_69's Avatar
an1mal_69
ok, yea im with you. Now you mention it, prop was marked up with tippex an i did put it back 'as is'
couldn't be the centre support for the prop then.? How much play should there be in it..seemed a bit baggy to me
Old May 28, 2009 | 10:52 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
4x4 or rwd ?
Old May 29, 2009 | 09:37 AM
an1mal_69's Avatar
an1mal_69
RWD, sorry..
martynhomer01
14
Sep 23, 2015 12:23 AM
Mark Mawson
Aug 31, 2015 07:09 PM
gabbo
Aug 28, 2015 03:56 PM
Archiejay
Aug 12, 2015 12:07 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
