whats causing my smoke?
Old May 25, 2009 | 07:57 PM
WongRS's Avatar
WongRS
Default whats causing my smoke?
Hey all, just noticed my saffs got a bit of a habbit
Its only just had a top end rebuild and newish turbo .
But after periods on overrun, when i hit the throttle again it chucks a noticable amount of blue smoke out, whats this point too?
There isn;t a whisper when its started from cold or anything, and after a bit of throttle it clears untill next time you have some overrun?
Old May 25, 2009 | 08:14 PM
Escos2483's Avatar
Escos2483
From: guernsey,c.i.. a rip off island , full of drunks
Smoke on overun mate normally suggests valve seals or stems ,,,, thats if its blue smoke ... The oil is being sucked down through the clearance between valve and stem when throttle is closed ... As your head is just been rebuilt it could be something else ,,, unless some stem seals have come away from there seats ... I had same problem with aftermarket seals and have no problem since i fitted ford seals ....
Old May 25, 2009 | 08:24 PM
WongRS's Avatar
WongRS
they wernt origianl ford ones, so i am guessing its those then, nothing major, will just have to live with the smoke, i'm not going to take the head off again yet just to do them.
Thanks for that.
Old May 25, 2009 | 08:32 PM
Escos2483's Avatar
Escos2483
No worries .. Just make sure all your breathers are clean etc as well .. If it was piston and bore wear,, it would normally smoke under load on throttle ... Regards mark
Old May 26, 2009 | 07:10 AM
WongRS's Avatar
WongRS
ok, thats a bit of good news then , thanks very much.
Old May 26, 2009 | 08:28 AM
Bore/ring wear can certainly cause what you have, engines don't always work to a pattern.
Old May 26, 2009 | 10:41 AM
Barry R's Avatar
Barry R
Mine does it after a blast when i come off throttle I get a bit of blue smoke
Old May 26, 2009 | 12:09 PM
Mine does it too, but at 160,000+ miles on bottom end I forgive it!!
Old May 26, 2009 | 02:01 PM
Barry R's Avatar
Barry R
Mines only done 69k
Old May 26, 2009 | 04:25 PM
bad boy rs's Avatar
bad boy rs
they all smoke, if it doesnt it prob hasnt got any oil in it
Old May 26, 2009 | 05:03 PM
WongRS's Avatar
WongRS
mine never used, and now this is fairly bad!
keep it revving untill it becomes i problem, thats my theory.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
