Distributor, should it have a O-ring?
Old May 18, 2009 | 07:33 PM
Andreas's Avatar
Andreas
Default Distributor, should it have a O-ring?
Took the distributor out to re-align it so it matches the mark for the aux pulley.
Shouldnt there be some kind of sealer on the shaft, like a o-ring or something?
Old May 18, 2009 | 08:13 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
yes m8,
Steve
Old May 18, 2009 | 08:30 PM
Andreas's Avatar
Andreas
Is it this black plastic looking ring?
Old May 18, 2009 | 08:36 PM
charlie luciano's Avatar
charlie luciano
Yes about 46 pence from Ford
Luciano
Old May 18, 2009 | 08:44 PM
Andreas's Avatar
Andreas
Is it made of rubber like a normal o-ring?
Mine seems like hard plastic so perhaps time to change it, lol.
Old May 19, 2009 | 03:55 AM
Moonstone Steve.
Should be a soft rubber m8, if yours is hard its time for a change.
Steve
Old May 19, 2009 | 09:23 AM
Andreas's Avatar
Andreas
Thanks, I have ordered one now.
Is it possible to get the distributor back in if I fit the head back on or will the intake cover block it? Just wanted to keep on working with the car so its ready to start up once the o-ring turns up.
Old May 19, 2009 | 02:24 PM
charlie luciano
Should be alright to remove and refit the dizzy with everything in place
Luciano
Old May 19, 2009 | 04:47 PM
As said o ring goes hard with age, bit tight for room but easily doable with head/inlet on already, just trim off any excess bolt thread that may be showing as if there is any closest to the cap it makes it harder to get cap on, mine had a good 1/2 showing.
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 29, 2015 11:27 AM
dms04
Sep 11, 2015 01:57 PM
Anutternutter
Aug 21, 2015 06:07 PM
Sjieter
Aug 5, 2015 09:47 PM
