sorting the rear end on a 3-door?
May 10, 2009 | 07:37 PM
ive had polybush kit sitting in the garage for must be 2 years,never got round to fitting
but i fancy a proper rear beam later this year,so what bushes will i fit when i get new beam,and im also going to solid mount the rear diff
May 10, 2009 | 08:07 PM
I keep toying with the idea of grafting a totaly different beam onto the back of mine....some thing a little more modern.
May 10, 2009 | 08:11 PM
use the normal bushes with it, maybe solid beam mounts, depends how much vibration you can put up with as you said you will be solidly mount the diff
May 10, 2009 | 08:13 PM
standard rose joint on the outer arm and modified rose joint on the inner
these are how the scs and ahmed beams are, they can use solid floor mounts or the polibushed ones
May 10, 2009 | 08:15 PM
cheers guys,i dont mind noise the rest of the car aint quiet
May 10, 2009 | 08:34 PM
i have soild mounted the diff and beam on the focus the vibration does take some getting use to lik
May 10, 2009 | 09:11 PM
sound mate,noise doesnt bother me
jessie_rs
11
Jun 3, 2019 04:57 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
