cosworth starting problems
Old May 4, 2009 | 03:04 PM
neilsrsturbo's Avatar
neilsrsturbo
cossie
Default cosworth starting problems
hi i've just done an engine rebuild on my sierra sapphire 2wd. i have put the engine back in but there is no spark at the spark plugs? thought it may have been the coil but tested the coil and it has a good spark. changed the dizzy cap and rotor arm still no spark. can anyone help me? i have put brand new motorsport leads on the car aswell.
Old May 4, 2009 | 03:27 PM
scoooby slayer's Avatar
scoooby slayer
sensor in the distributor. think its called a phase sensor. there cheap to.
Old May 4, 2009 | 04:29 PM
Do you have a pump prime when you first switch on first thing of the day ?
If yes you know you are getting a cps signal, if not look at this, I think it is possible to accidentally mix up the cps and dizzy terminal connectors, especially if connector on cps has been changed to black, can't remember if both side were white or just the connector side and not the loom side.
I would just go through everything and recheck bound to be something daft and silly that you will slap yourself for when you see it!!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Aug 14, 2015 07:29 AM
Sjieter
Aug 5, 2015 09:47 PM
