T34 .48 or .63 housing,advise needed.
Old Feb 25, 2004 | 08:24 PM
Default T34 .48 or .63 housing,advise needed.
Ok i have a 2wd cos with a standard bottom end 205 block wire rung, 2wd head that has been overhauled (apart from followers) & Grp A h/gasket, the engine is in perfect condtion,doesn't smoke whatsoever & uses hardly any oil (about a litre between oil changes 4k miles). Currently running 803's,-31,3bar,bayjoo chip supplied & setup by MA developments last summer, still running standard turbo T3 about 1.3- 1.5 bar (21psi ish). Only made 288bhp & 294 lbs at Eng Advantages last year,was a bit disappointed as i hoped to hit a magic 300bhp but never the less it has been very reliable & gets thrashed. Since this i have changed from a 4x4 i/c to a Radtec 500 i/c, next mod is to get a bigger turbo but there seem to be a fair few T34's for sale with the .63 housing secondhand, don't seem to see many with .48 housing secondhand. I can't justify spending £650 on a new one at the mo. With my engine as it is being standard head & block i am never going to get more than 330 -340bhp so would it be better for me to wait & try and find a T34 with a .48 housing for sale as i wouldn't benifit from the .63 because i'm not going for megga power. The last thing i want is a laggy motor because at the min it spins up really nice but I'd rather go for a T34 to get that bit extra. Any advise appreciated.
Cheers Simon.
Old Feb 25, 2004 | 10:57 PM
PJay's Avatar
PJay
You can get 400 bhp on a standard engine, a t34.63 will bring you close to this mark if you change to grey injectors, realisticly 375ish can be acheived, if you wish to retain your green injectors 350bhp is posible with a t34.48 or .63.
if you were to buy a t34.63 .48 housings are available for around £150 from TT and you'll have no problems selling the .63 housing as there in fairly high demand.
Hope this helps
PJay
Old Feb 26, 2004 | 06:55 AM
alan rainbow's Avatar
alan rainbow
not much difference in lag between a .48 and .63 i hardly noticed on mine
Old Feb 26, 2004 | 07:10 PM
Thanks for the reply P Jay & Alan, seems like it doesn't make much diff lag wise whether its a .48 or .63 ex housing. I didn't realise you could get so much power from a standard engine, what boost roughly would you have to run on greys t34 .63 to get 370 ish ?
Cheers Simon.
Old Feb 27, 2004 | 06:58 AM
alan rainbow
depends on engine spec but probly about 26 - 28 psi held
Old Feb 27, 2004 | 02:57 PM
Milko's Avatar
Milko
Would standard pistons take, holding 28psi?
Cosnada
Jan 7, 2016 05:30 PM
fordrallycar
Sep 30, 2015 07:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
