Sump plug problem, new gasket and still leaking..
Old Apr 28, 2009 | 06:41 PM
Antti O's Avatar
Antti O
Default Sump plug problem, new gasket and still leaking..
Yep. I did drain oil and did change sump plug gasket. Genuine ford item. Now it still leaks.
What i do?
Old Apr 28, 2009 | 06:46 PM
orionmojo's Avatar
orionmojo
you could try two washers (copper ones)
Old Apr 28, 2009 | 06:48 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
What i do?
Try a new plug and new copper washer mate and see what happens.
Torque setting for plug should be between 21 to 28 Nm. I do mine 25Nm
If it still leaks then it could be the sump pan itself.
cheeRS
Chris
Old Apr 28, 2009 | 07:00 PM
Antti O's Avatar
Antti O
cheeRS
Chris
Do ford still sell sump plugs?
Old Apr 28, 2009 | 07:07 PM
orionmojo's Avatar
orionmojo
Stu @ M Developments sells magnetic ones on here. around Ł20 i think.
Old Apr 28, 2009 | 07:11 PM
Cossy Mike's Avatar
Cossy Mike
Yes they are less than Ł2 I have a bag of about 10 and about 20 washers.
Can't have enough of things like that....
Old Apr 28, 2009 | 07:26 PM
Antti O's Avatar
Antti O
Okay i have to call tomorrow local Ford dealer.
What gaskets you do use?
Old Apr 28, 2009 | 07:32 PM
Cossy Mike's Avatar
Cossy Mike
I just use the standard ones, there are like a plastic nylon type of thing. I'll see if the number is on the bag if you want?
Old Apr 28, 2009 | 07:46 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
halfords,Ł2.45
Old Apr 29, 2009 | 04:03 PM
rstdave's Avatar
rstdave
As above any motorfactors/halfords do them. They always seems to weep after a while though, i've got a new sump, change the copper washer every oil change and still find it weeps again after a period of time.
Old Apr 29, 2009 | 07:56 PM
Antti O's Avatar
Antti O
I bought new sump plug from Ford today. I put new plug and copper washer and still leaking.
Then i tried new plug with that plastic washer and that leaks even more. Then i have coolant leak also, when car cools down at the garage i found some coolant under the car. I spotted it directly under crankshaft pulley, can new QH waterpump leak?
Engine has done only 300miles after proper and expensive rebuilt.
Old Apr 29, 2009 | 08:37 PM
haz87's Avatar
haz87
Are you tightening things to the correct torque? If the two new parts you've fitted are both leaking it seems to say that there not being tightened properly?!
Old Apr 29, 2009 | 08:47 PM
Cossy Mike's Avatar
Cossy Mike
Have you double checked to make sure you have not cross threaded it?
Or someone else for that matter.....
Old Apr 29, 2009 | 09:31 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You sure its leaking from the actual sump nut? It's the low point of the sump and given that these sumps almost always leak, are you sure the leak isn't higher up, but collecting around the sump nut?
Old Apr 29, 2009 | 09:51 PM
jerh20's Avatar
jerh20
If its still leaks after the new plug and washer u could always as a last resort get a nut welded on as its prob the threads on the sump that r are fooked. just make sure the nut is the same thread obviously. Should be sealed after that and its cheaper than a new sump.
Old May 2, 2009 | 01:58 PM
Antti O's Avatar
Antti O
1. I have new rebuilt engine done less than 300miles
2. I lifted car way up and look after filling oil and i know exactly where oil is coming from. I can see 2-3 min after pouring oils to engine how its start to leak. I can took video if you want
3. I put it 25nm with special tool (new plug & seal ring) leaks badly.
4. Then i put copper washer and turned it pretty tight i say something like 70nm and it holds almost =)
Old May 2, 2009 | 01:59 PM
Antti O's Avatar
Antti O
I am pretty sure of that, because sump nut has always went okay without any tools and just tightening with tool.
Old May 2, 2009 | 03:37 PM
iansoutham's Avatar
iansoutham
OCD Victim
Order a sump plug washer from a diesel "1005578". It is metal with a rubber seal built into it. That should not leak, @ least it never has on any of the loads of cars I fit them to...
Old May 2, 2009 | 04:01 PM
Antti O's Avatar
Antti O
Many thanks i will try that.
Torque fiqure?
Old May 2, 2009 | 07:11 PM
Cossy Mike's Avatar
Cossy Mike
Torque fiqure?
25-30Nm
dont think it will work though. Even the plastic nylon washers should be enough.
Best of luck though
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Chopshop85
Sep 12, 2015 06:42 PM
BRAM
Sep 8, 2015 07:11 AM
little bram
Sep 7, 2015 11:59 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
