siemens injectors
what are you trying to achive by fitting them? you know you need a chip to suit carnt tust fit siemens as the car wont run at all. if you have greens and have no plans to live map or upgrade there is no advanatage imo
if you have greens already, no point i changing
if you do you'll need a new chip, and you wouldnt notice any difference
if you were increasing power and needed new/ bigger injectors then i would recommend getting Siemens
You could get more power with 55lb's than greens? On a standard engine with a suitable tubo.
Eg greens on a t34 do what 350? 55lbs will do 380ish? Mates sapph did 420 something with 55lbs and a t4.
mk3ste
Oct 17, 2021 10:09 AM
timsrs
22
Sep 24, 2015 08:14 PM
