siemens injectors
28-04-2009, 03:27 PM
siemens injectors
will siemens injectors fit to stage 3 with no headwork or cams?
cheers
28-04-2009, 03:31 PM
Yup,got some on mine,although i'm after a ported head.
28-04-2009, 03:43 PM
are they a lot better than greens?
28-04-2009, 03:48 PM
I honestly think so m8,stu @ MSD does too so thats good enough for me.
28-04-2009, 03:57 PM
i was thinking of changing to siemens 55's, but whats the advantages?
28-04-2009, 04:05 PM
what are you trying to achive by fitting them? you know you need a chip to suit carnt tust fit siemens as the car wont run at all. if you have greens and have no plans to live map or upgrade there is no advanatage imo
28-04-2009, 05:13 PM
bit more power, yeah i know was gonna get injectors then down to karl norris for live map was hoping for around the 400 bhp mark
28-04-2009, 05:26 PM
Quote:
Originally Posted by
cossiedan1983
siemens come in 55lb, 72lb, 83lb but they are all priced the same
28-04-2009, 05:28 PM
shaun655
if you have greens already, no point i changing
if you do you'll need a new chip, and you wouldnt notice any difference
if you were increasing power and needed new/ bigger injectors then i would recommend getting Siemens
29-04-2009, 06:47 PM
You could get more power with 55lb's than greens? On a standard engine with a suitable tubo.
Eg greens on a t34 do what 350? 55lbs will do 380ish? Mates sapph did 420 something with 55lbs and a t4.
01-05-2009, 09:58 AM
My set of dark greens were maxed, well 80% at 310bhp, but seen plenty do more, mine had just been cleaned though.
01-05-2009, 10:04 AM
hee hee! siemens injectors.
mk3ste
17-10-2021 10:09 AM
Mark_
14
16-01-2016 05:27 PM
01-11-2015 06:53 PM
timsrs
22
24-09-2015 08:14 PM
cos elle
16-09-2015 06:37 PM
