1.8 TD engine
Old Apr 16, 2009 | 03:45 PM
Beamer S100's Avatar
Beamer S100
Default 1.8 TD engine
I have a 1.8 TD engine inside in a P100. It bog standered. What can I do to get more bhp/torque?
Old Apr 16, 2009 | 10:04 PM
cosrep's Avatar
cosrep
Induction kit with a cold air feed, custom intercooler installation and then have the boost and fueling turned up - good for 130 to 140bhp
Old Apr 17, 2009 | 11:32 AM
cjwood555's Avatar
cjwood555
Does anyone know of any off the shelf i/c kits? How good is the standard ford i/c? My escort has the non-intercooled installation....
Old Apr 17, 2009 | 01:11 PM
Beamer S100
Would a sierra cosworth intercooler do? What the best make induction kit and what size?
Old Apr 17, 2009 | 01:29 PM
turbo_bettsy's Avatar
turbo_bettsy
EFI converted
Put an LPG conversion on it, more bhp and better miles if your easy on the right foot.
Old Mar 21, 2011 | 08:46 PM
johnhonda800kk's Avatar
johnhonda800kk
how do you turn up the pump and boost
Old Mar 30, 2011 | 08:46 PM
johnhonda800kk
hi i have a p100 how do you turn up the pump and boost
Old Mar 30, 2011 | 09:02 PM
Escow-Van's Avatar
Escow-Van
The Escort and Mondeo have top-mount inter-warmers above the exhaust manifold. Obviously a front mount would be better.
This video gives detail on Peugot engines, but the principles are the same. There are obviously additional parts.
http://www.youtube.com/watch?v=X4l5on3_IrA
Old Apr 4, 2011 | 12:05 AM
crumpet's Avatar
crumpet
the ford 1.8 td engine is pretty useless to be honest! Ive tuned many pug 1.9 td engines with great results in the past, the 1.8'scome with the shite lucas fuel pump ( as shown in darrens video^^) which cant really make good power.
You can fit an intercooler easily enough all you need is 2 90 degree pipes for the turbo and inlet manifold ( or find a non turbo inlet manifold) and some boost pipes, a 4x4 cossie intercooler would be fine.
The fueling would have to be adjusted by the max fuel ( black screw in cap on the front) annd the boost compensator (14mm locknut also on the front of the pump) you can also advance the timing of the pump by undoing the 13mm lock nuts and rotating the pump upwards.
Boost shouldnt run more than 20 psi as the turbo will run out of puff and will just make less power.
Old Apr 4, 2011 | 01:09 AM
taittsierra's Avatar
taittsierra
you not goen to get much out of it lad i tryed .......wat i done was turn turbo pressure up an adjust the fuel timing with a tdi intercooler an air filter but wif dat id ssay was only gett 100 if dat?
change for a 2.0 twin cam from a sierra!
Old Apr 4, 2011 | 05:10 AM
Frenchy0204's Avatar
Frenchy0204
Get to tha choppa!
You taking the piss? 140hp?!?!
I seriously doubt that mate.
Old Apr 4, 2011 | 06:53 AM
m4tt274's Avatar
m4tt274
the standard 1.8 TD p100/sierra doesnt have an intercooler.
putting one on will help a fair bit.
you can turn the fuel and boost up, put a big K&N on it, big pipe and and an intercooler but you will probably only see 110bhp
i turned the boost and fuel up on one and ran it with a down pipe and an old group A filter from a cossy and i only had 97bhp :/
Old Apr 4, 2011 | 06:11 PM
Add NITROUS, seriously can add 75bhp totally safely, it works far better on diesels than petrols.
Old Apr 7, 2011 | 09:36 PM
johnhonda800kk
ok then i heard a fella used a mk2 mondeo engine he said it was a stright swap just 12 volts to the pump and away you go is this true
Old Apr 7, 2011 | 09:39 PM
crumpet's Avatar
crumpet
nope, they have an ecu, mk1 td engine is 100% mechanical and only requires 12v to stop solenoid on the fuel pump
Old Apr 7, 2011 | 10:26 PM
johnhonda800kk
so i would have to use the whole loom out of the mondeo or just the engine wiring harness
Old Apr 7, 2011 | 10:27 PM
crumpet's Avatar
crumpet
not worth it Imo, mk1escort/mondeo td engine is best off buying
Old Apr 8, 2011 | 06:44 AM
m4tt274's Avatar
m4tt274
would the mondeo engine not mount the wrong way?
Old Apr 8, 2011 | 08:01 AM
Bailes1992's Avatar
Bailes1992
Lucas pumps can make power, they are just smokey off boost compared to Bosch pump engines.
I reckon a good intercooler, induction kit and a fairly straight through ehxuast will be all thats needed interms of hardware. After that it's just turn the turbo up and the fueling, maybe advance the pump slightly.
Also stick 200ml two stroke oil in with every tank of diesel
Old Apr 8, 2011 | 11:14 PM
johnhonda800kk
why the two stroke
Old Apr 8, 2011 | 11:22 PM
crumpet's Avatar
crumpet
Fuck 2 stroke, use parrafin, thats what i ran my zx on, was the quickest td/zx-306 ever in my town and shat all over vts's and r5 gt turbos.
Old Apr 9, 2011 | 03:04 PM
Bailes1992's Avatar
Bailes1992
The two stroke helps lubricate the pump and makes the engine smoother.
Also was having a think last night.
Didn't Sierras come with a Peugeot 2.3D engine?
Now if you could get the gearbox off one of them then Peugeots XUD9TE engine should bolt straight upto it.
An XUD9TE with a well modified pump, straight through exhaust and an FMIC will make 140-150bhp.
If you can get an XUD9TE with a bosch pump then you can run it on 100% Vegtable oil too.
Food for thought?
Get it... Vegtable oil / Food for thought
Ahh my comedy genius is wasted on you lot
Old Apr 12, 2011 | 08:08 PM
johnhonda800kk
hi i also want to put power steering in it i have a pump and ract of a 1.8td sierra will that rack do or do i need a granada rack or just put on granada track rods on the sierra rack
RUBY123
Oct 22, 2023 12:04 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
taylora1409
Aug 12, 2015 12:06 PM
knight19770
Aug 4, 2015 12:36 PM
