Cossie smoking advise please
After you boot my car it smokes when you put your foot back down
whats a common cause for this? the turbo has no play it feels mint
but could the seal in it be knackered , breather issue ? valve stem oil seals?
ive had plenty of cossies & this is exessive after booting it when you put the foot down again it a fair bit of blue smoke i would suspect turbo but its nice n tight no play in the shaft
yes mate, they all do.
not too sure on that question Carlo.
could be a number of things mentioned above Carlo,hard to find what if all is ok with everything.
can you put up with it or is there loads of smoke..
can only hazard a guess
try overrunning down a long hill, and give it a boot at the bottom, if it puffs out blue its likely to be worn guides or stem seals
if it really bothers you and you're using shit loads of oil, then i would start with the cheapest, like a rebuild on the turbo, circa Ł200 (assuming only seals and a balance)
then i would start looking at worn oil rings, but these dont show on a comp test, so if you're gonna pull it apart you might as well give it a refresh
Cheers, Matt
Cheers, Matt
Fuck , i prob wouldnt rebuild my engine i would maybe just buy a standard 4x4 engine have it rebuilt & stick it in cant be bothered with the car being off the road for any length of time
I'd check the inlet plenum elbow for signs of oil if there is some in there take the compresor to cooler pipe off and check there if oil is coming out of compressor if there is then its turbo
A sticky oil residue is normal but oil drips is a problem as it collects in cooler and on boost chucks it into manifold which then when u let off creates vaccum and sucked in by engine and burn't
Paul
Paul
I know its a different application... but my DC2 Integra TypeR was doing similar and I replaced the valve stem seals which cured the problem.
As well as giving it large into VTEC and then allowing it to come down on over-run and putting foot back down, I found that sitting on the spot revving to the high to mid rpm-range, letting it run down a couple of 1000 rpm and blipping the throttle was producing a bit of blue smoke from the exhaust.
Cheers,
Grant
Cheers,
Grant
ah sorry missed that! if its after overrun when you bring back on the power its normally valve guides/seals as most bottom ends/turbos ive seen or had go on me normally smoke whilst on power....
If it was stem seals & valve guides im not bothered i would buy a head & have it reconed , it certanly seems like its only doing it on vaccum but when its cold first thing in the morning it dosent smoke a bit
Russ Payne
Sep 25, 2015 08:29 PM
