rs turbo rear disks
anyone clued up on these a just bought a series1 with a set of 2wd cossy discs but it has standered turbo discs on the front seem ok but not had to slam on yet can anyone see this causeing a problem
where u get the iger stripes was thinking of doing that to mine as i remember when they first came about in the early 90s the met grey series 2 looked mit with the green and light grey ones
Yeah big problem mate as KidRS said!! RIP his S1!!
I'm slapping Focus ST 300mm bad boys on the front of mine as I dont want the risk, even then i'm going to test them and perhaps add a bias valve to be sure!!!
This came up a little while ago and I said about the over breaked rear end and promptly got shouted down by a couple of users. I hate to see anybody damage their cars but maybe the shouters from the other thread might like to now read this?
Passionate about fords
get shot of the rear compensators too !!!!!.
or go the whole hog and get braided lines throughout and a custom pedal box replacing the servo with in-car adjustable bias on the dash ( like moi )
dave.
dave.
im ruunning 2wd cozzie set up on the back,got st170 set up on the front no bias valve never had the back lock up on mine the compensators were also removed
Although I think mine is differnet to normal RS's it's the same as the van and estate models, just one in the middle at the back. Dont know if that makes a difference?
If its locking up on the back and your on standard suspension you will possibly want more braking on the back not less, so reducing it with a pressure reducing valve is going the wrong way
I'm on Spax adjustables BTW, i've not actually had mine lock up but after hearing about KidRS i'm concerned.
orion=mini saff
so did i bud!always said there a bad idea!!
I think where Tony is going is that because teh front is braking hard the weight transfers to the front thus making the rear of the car light and as a result more likely to lock up. By increasing the effort the car will brake more level and thus stop quite such an excessive transfer of weight away from the back of the car
you must have read my PM I sent to Karlos this morning If it locks up under braking it could actually need more on the back to stop it, depending on what its doing.
Don't ask - I don't know
I think it's going to be a bit of trial and error with a bias valve to get the balance between front/rear just right then.
Im running the same as you still with the rear compensators and ive had no bother, i know ive driven that hard enough as come back the other day and all 4 brakes where smoking, but thats what you get when trying to stop a YB powered rst.
gmax with 30mm drop im tryin to keep costs down so was just wondering if the std turbo callipers with cossie discs on front will be ok with the complete 2wd rear disc conversion its only a road car and i use it everyday
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
