what do i do.... some help please
Old Apr 5, 2009 | 06:12 PM
nickrsturbo1990's Avatar
nickrsturbo1990
Default what do i do.... some help please
hi there people.... could do with some good advice
just rebuilt my s2 erst
rebore 0.5 oversized mahle pistons
crank was polished new shells
stage 2 head
and a new stage 2 t3 from cr turbos
so basically ive got gotech engine managment and the engine is going back in the car next week.
im a bit confused on what to do next as its basically a brand new engine do i take it straight to the rollers (jamsport) and get it setup or do i run the engine in for a bit
im scared that if i take it up to them to get it remapped before running it in and they ragg it that it will blow straight away help please
Old Apr 5, 2009 | 06:50 PM
stevenebm's Avatar
stevenebm
post whore
i dont think you need to worry about jamsport mate,
Old Apr 5, 2009 | 06:58 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I'd run it in before I got it setup, until the piston rings bed in your compression will be down slightly! If you have it setup now and the the compression raises after the rings bed in you might get detonation and ruin those nice new shiny pistons and or your new head.
I dont know how likely this is but just a thought mate....
Old Apr 5, 2009 | 07:01 PM
nickrsturbo1990
Originally Posted by Karlos G
I'd run it in before I got it setup, until the piston rings bed in your compression will be down slightly! If you have it setup now and the the comp raises you might get detonation and ruin those nice new shiny pistons.
how many miles should i run it in for before i go and get it setup???
also theres a new stage 2 t3 goin on the car
Old Apr 5, 2009 | 08:59 PM
boothy's Avatar
boothy
1000 miles mate, you are in good hands with jamsport
Old Apr 5, 2009 | 09:00 PM
nickrsturbo1990
so should i run it in for a 1000 miles before taking it to jamsport to get setup?
Old Apr 5, 2009 | 09:05 PM
boothy's Avatar
boothy
Yes mate, just get some miles on it. Dont go over 3k and warm it up and let it cool down well. then you will be ready for it to be setup,
Old Apr 5, 2009 | 09:08 PM
B16CVH's Avatar
B16CVH
Do 500miles, change oil & filter, same again @ 1000, when you get to 1500 drop the oil & filter out again then put some top quality lube in there then get it setup. Just take it very steady and dont take the revs above 3-3.5k if you can help it.
boothy's Avatar
boothy
Yes mate
Old Apr 5, 2009 | 09:13 PM
nickrsturbo1990
ive gt silkolene pro s ready to go in after its been run in
but bin told to run it in on millers running in oil 10w 40 ??
Old Apr 5, 2009 | 09:16 PM
B16CVH's Avatar
B16CVH
Yes that is what i always use, never had a problem at all, its good stuff (millers). Never use anything more than mineral while running-in as you will prevent the rings etc bedding i and your engine will never perform as it should. (blowby/oil consuption)
Old Apr 5, 2009 | 09:19 PM
nickrsturbo1990
ok thanks for the help guys really ppreciate it
but just clarify drive under 3k for 500 miles on millers oil and then change the filoter and oil.
and then do the same for another 500 on millers change the oil and filter
and then would it be ready for a setup in jamsport after a 1000 miles
ive also chanhged the turbo to a stage 2 t3 will this effect the running in?
Old Apr 5, 2009 | 09:21 PM
B16CVH's Avatar
B16CVH
Yes, some people say setup @ 1000 miles but i have always let it run for another 500 miles to 1.5k,always think its worth it having shelled out for a new engine.
Old Apr 5, 2009 | 09:24 PM
nickrsturbo1990
oh ye definately...... is it safe to drive the car tho because the fuel mix will be all wrong on my car now as it was overfuelling before it blew.... thats y i was confused and i have gotech managment
Old Apr 5, 2009 | 09:30 PM
B16CVH's Avatar
B16CVH
You can drive it but keep the boost down (i always set it back to the std 8psi). If you can get the CO checked and adjusted so it is not terrible then you will be just fine.
Old Apr 6, 2009 | 12:07 AM
nickrsturbo1990
CO checked???
Old Apr 6, 2009 | 12:19 AM
tiff_lee's Avatar
tiff_lee
If you're putting a new turbo on as well you might want to get an inline filter before the turbo especially as you're running in.
Old Apr 6, 2009 | 12:23 AM
nickrsturbo1990
whats an inline filter?
Old Apr 6, 2009 | 12:36 AM
tiff_lee's Avatar
tiff_lee
Just a small oil filter to go before the turbo, something like this ...
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=BAITOF31
just think all those parts are going to wear and all that contaminated oil is then going to go through your nice new turbo! I'd definitely get a magnet sump plug to.
Old Apr 7, 2009 | 06:09 PM
nickrsturbo1990
i took ur advice mate and got the inline filter and a mgnetic sump plug
Old Apr 7, 2009 | 07:54 PM
tiff_lee's Avatar
tiff_lee
Oh you did cool lol I hope they serve you well just remember to clean the inline filter regularly during runing in and at every oil change i'm sure the magnetic sump plug with speak for itself.
Old Aug 22, 2009 | 03:39 PM
martinmilne's Avatar
martinmilne
how did the running in go did you get it set up
Old Aug 22, 2009 | 04:15 PM
nickrsturbo1990
still running it in got it setup bout 3 weeks ago and have done 400 miles so far but now my immobilizer has decided to pack in and is now on standby till next weekend
Old Aug 22, 2009 | 05:06 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
some great advice there, but if it's overfuelling you'll suffer bore wash and ruin the bores/rings.
get it over to a tuners and get them to set fuelling for low load and drive it gently for a bit, then get it mapped for full power.
shauns
Fitness / Weight Training Discussions
Sep 13, 2013 08:22 PM
crumpet
Jul 11, 2012 08:16 AM
hevangel
162
Mar 22, 2012 02:57 PM
knighty444
Feb 5, 2012 11:18 AM
The Beer Monster
46
Jan 4, 2012 06:45 PM
