Wanna turn up my boost
Are you on the lookout for a new engine?
Turning up the boost is a major engine killer without it being setup to cope with the extra boost as your fueling will be out
best thing to do mate! its not worth the price of a rebuild.
and for the record, more tension = more boost!
best way to do it, is set the actuator to be just tensioned so the hole sits half over the wastegate dowel thingy, then run a bleed valve.
Yea your right mate just being experimentif wanna learn all a can. How much psi can my standerd actuator cope with???
rsguy
44
Sep 29, 2015 03:29 PM
Russ Payne
Sep 25, 2015 08:29 PM
