Problem with cold start injector
Old Mar 29, 2009 | 04:13 PM
cj_rst's Avatar
cj_rst
S2 RST
Default Problem with cold start injector
If I have it connected (multiplug on the back of the inlet manifold) my car refuses to start. Fuel pump primes ok but the starter motor doesn't even turn. Nothing. If I then disconnect the cold start injector it'll fire up with no problems at all! Any ideas?!
Old Mar 29, 2009 | 06:25 PM
boost monster's Avatar
boost monster
Leave the cold start disconnected!!!
Old Mar 29, 2009 | 07:12 PM
cj_rst's Avatar
cj_rst
S2 RST
Surely it should have it for cold starting? Having said that, it does start ok from cold with it disconnected... Just wondering why the starter doesn't even turn over really?!
Old Mar 29, 2009 | 08:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah thats a strange one mate?! Must be some sort of wiring problem (er... obviously lol ). I'd take a look at the starter wiring first!
It starts without the cold start injector ok because your main injectors are probably leaking whilst the car is stood up and so there is plenty of fuel in there for a cold start (this is the most common reason for unpluging the cold start injector, when really the main injectors should be replaced!).
Old Mar 30, 2009 | 01:00 PM
cj_rst's Avatar
cj_rst
S2 RST
That makes sense I guess. I know my starter wiring isn't the best - the exhaust is waaay to close to the starter, I thought there was a bit more room usually but the cars got a massive s/s exhaust straight from the turbo... Might need to change that, lol
Old Mar 30, 2009 | 07:22 PM
ben skinner's Avatar
ben skinner
I own a money pit!
lag the exhaust and lag the starter with reflective laggingdid this to mine when i replaced starter
worked a treat
manuel boeckx
13
Oct 3, 2015 02:29 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
Zoggon
Aug 10, 2015 10:39 AM
