HI ALL, has anyone had trouble fitting powerflex strut top mounts, I tryd to fit mine tonight and the problem im havin is i carnt get the nut on the top, the shocker wont go up through the strut top far enough with the powerflex bushes in place, Any info would b great cheeRS.
have u compressed the spring enough to the point that the shock is fully extended? otherwise there wont be sufficient thread exposed to begin tightening the top nut
drop the strut out, compress the spring, and tighten down the spring cap nut as far as poss, then u shud have enough thread exposed to solve the problem
tried covering it in WD40, then maybe using a jack to force it thru enough to start the thread? then it tends to be a matter of impact gun time and tighten the fucker up
my poly top mounts were tight, but not this bad i wil admit
Once you've assembled it all, don't put the top nut on until the car is back on the ground with all its weight down, then it should go together. You tried this?
Yep tried jack n wd40 but its lifting the car off the axel stand its proper tight, its about 1/4 inch short, my shocks are koni adjustables n springs are 40mm spax, ive no idea why it wont go, just thought id see if anyone else has had the same problem
looks like i have cheapies lol didnt buy them new got them off a lad on here sellin gaz coilies and strut braces, not had any issues with them tho 3 years on..yellow ones do look better tho!
Well, I'm not the worlds biggest fan of Poly-Urethane bushes anyway, they do wear quickly. But if you ask me, Powerflex are as good as they get for Ford's. I wouldn't use anything else.
I fitted the same yellow Powerflex top mounts with my GAZ coilover... I could not get it to work either... ended up using the original Ford black rubber item...
There is no issue? I've just replaced the Powerflex top mounts that I fitted almost 10 years ago with a new set and they went on fine with my Gaz Golds. Once you guide the shock into place and lower the weight back on, the nuts will go on fine.
Just got back from garage problem solved thanks to christians advice,cheeRS mate! They go straight in once u drop the car on the ground, Thanks Fellas!
