will beiges be alright?
Has a large member
i did a search but couldnt find anything so...
wondering if my beiges will be ok for my spec or will i need some green 803's?
1.8zvh
195chip
gas flowed head
t34 turbo
front mount
cossie pump
external wastegate and screamer
will be running 13-14psi, and will be getting car set up. just wanna turn up with the right spec to save money/time on the rollers.
cheeRS
1.8zvh
195chip
gas flowed head
t34 turbo
front mount
cossie pump
cheeRS
Has a large member
i would say i need bigger ones too. wat is the next size up then if i cant fit cossie greens? from what i remember beiges are maxed out at about 220bhp, which i cant see my set up making more than that at only 14psi, but i just dont want the injectors to be on there limit
yea apparently mine is ofab and was live mapped on the fiesta ofab ecu however till i get in the tuners i shal nmot know this
if u use cossie management u will need the right injectors for the mamagemnt as they run of different impedences.
195 chip will not work you will need a custom live map. t34 is to big. you will need green lancia delter injetors or the evo 2 delter bieges which is in good for 350 but that will be over kill for 1.8.
Has a large member
guy i bought front mount off threw in the brand new t34 in for not much more so i bought it as i didnt have much life left in my current t3. but sadly it seems to be making my life a lot harder now lol. i know its gonna be laggy on a 1.8, but i just want safely running lump now and dont care bout figures/drivabilty.
do you reckon i could get an off the shelf ahmed chip for this set-up and then run suggested injectors?
Has a large member
cheers for the reply.
its all starting to sound expensive
if i was to take a step back and flog my t34 and go for a standard t3 running 14psi do you reckon my beiges and 195 could handle themselfs then?
or am i still in the same postion?
right best thing to do is sell the t34 and get a big t3 ie 63 houseing 55 trim phone grove and talk to mark about a chip for 1.8zvh and tell him your spec and he tell you want you need!!!
