Machining engine components
Old Nov 30, 2004 | 05:40 PM
fo0q's Avatar
fo0q
Default Machining engine components
I'm gonna start building a 2.0 N/A zetec soon which i hope to get to around 200 BHP which will be goin in my 5b escort and have a few questions.
Gonna start stripping it soon and am gonna concentrate on the block first but i want to know.
1) how much power would a untouched std crank be ok for?
2) it'll have new shells throughout but would it be worth having the crank ground down with bigger bearings?
3) what are the stages of grinding a crank starting from a std one..my boss has been talking about thous of a inch and such but i dont understand these terms to well.. how much should a crank be ground and then what size bearings should it have
4) also what about boring out the cylinders. i've heard of boring out to .5 from std.. what are the stages of this?
5) and Can i use forged accralite pistons with steel rods on a std crank?
thaks in advance... this is my first engine build and just gatherin info befor i start.
Old Nov 30, 2004 | 05:55 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Default Re: Machining engine components
450+ it seems
Depends on the condition of the journals, if they are fine and still std size, then use std size bearings
A machine shop will sort that mate, leave it upto them
Just bore it out so you have a clean bore, usually youd start with 0.25mm oversize, if the existing bore is std and worn. If its 0.25 oversize already, you'd go out to 0.5mm oversize etc
Of course!
Old Nov 30, 2004 | 06:04 PM
fo0q's Avatar
fo0q
cheers mate thats a great help..
one last thing for tonight, if i bored out a std cylinder 0.25mm bigger.. can you get bigger rings for it or would ya need the next size up in piston.
i know i should wait till the engine is apart so i can meaure it all but would feel better with the info on board first.
Old Nov 30, 2004 | 06:13 PM
Moonie's Avatar
Moonie
You would need oversize pistons to match the bore size
big_Rad
Sep 15, 2017 09:36 AM
Bailes1992
Sep 3, 2015 02:17 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
taylora1409
Aug 12, 2015 12:06 PM
RSmark84
14
Aug 3, 2015 08:09 PM
