dot 5.1....silicone or non
saff is working!!!...atm
i use 5.1 and i'm needing some more but can i fook remember....think it silicone based i need but please comfirm...........
not entriely sure. cant find the site i used the other day... but it explained that all DOT 5 fluid is silicone baised, and gave the boiling figures as higher than DOT 5.1 but it eats seals. hence DOT 5.1 (Glycol Based) is used as it has a longer brake life and doesnt eat selas...
HTH
HTH
Silicone fluid is compressible compared to normal fluid and also as it is non-hygroscopic it means water will collect in pockets in your fluid rather than just being 'held' within it.
This can lead to problems in very heavy braking and with brake pipe corrosion
RichardPON
Feb 17, 2006 06:30 PM
RScrew69
30
Nov 3, 2005 07:49 PM
Fiecos Dan
40
Aug 3, 2005 05:46 PM
AKRS1
Apr 16, 2005 10:54 PM
moment! lol
