missfire problem !!!!!!
Old Mar 8, 2009 | 09:06 PM
cossie daz's Avatar
cossie daz
Default missfire problem !!!!!!
hi peeps,
put my engine back in the cossie after new head gasket and rebuilt head and got a missfire ,checked leads ,dizzy cap is new and new rotor arm.
still missfiring
anyone any ideas ?????
Old Mar 8, 2009 | 09:09 PM
Gary F's Avatar
Gary F
Plugs?
Old Mar 8, 2009 | 09:20 PM
cossie daz's Avatar
cossie daz
new plugs mate,
just finished out in garage,if you take 1 lead off at a time when its running on number2 doesnt make a difference at all.
Old Mar 8, 2009 | 09:22 PM
cossiedave's Avatar
cossiedave
had it on mine once may be the wires in the plug on the injector m8
Old Mar 8, 2009 | 09:23 PM
cossiedave's Avatar
cossiedave
or do a comp test
Old Mar 8, 2009 | 09:27 PM
BMEP's Avatar
BMEP
Originally Posted by cossie daz
new plugs mate,
When you removed the plug lead on number 2, were you getting spark from the lead to the block? If so, check the fuel injector plugs. In the past I have seen one of the pins in the injectior plug connector retract and not fire the injector.
Danster76's Avatar
Danster76
Originally Posted by cossiedave
or do a comp test
+1
Old Mar 8, 2009 | 09:32 PM
cossie daz's Avatar
cossie daz
think will do comp test and look at wiring loom 2 !!!
cossies, dont you just love em
Old Mar 8, 2009 | 09:35 PM
Simmo's Avatar
Simmo
Stick with it Daz, you're almost there!!!
Do you know if you've definately got a spark on No. 2?
Old Mar 8, 2009 | 09:44 PM
cossie daz's Avatar
cossie daz
hi simmo,
yes got a spark on no2, just wont clear,
sounds like anti lag
Old Mar 9, 2009 | 05:55 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I agree
Check the simple things first
Steve.
Old Mar 9, 2009 | 08:46 AM
cossie daz's Avatar
cossie daz
cheers peeps
Old Mar 9, 2009 | 12:49 PM
cossie daz's Avatar
cossie daz
Have done compression test on all 4 cylinders and that is good
THANK GOD !!!
The misfire is spitting out the exhaust and sounds like anti lag with the popping, it also seems very flat when giving it some revs
Any ideas ???????????
Thanks in advance
Old Mar 9, 2009 | 04:23 PM
onslack's Avatar
onslack
thats good news daz
Old Mar 9, 2009 | 04:39 PM
IANS2RST's Avatar
IANS2RST
you haven't mixed up the iscv plug with the injector plug? easy to do if its a 2wd loom as the plug is the same colour iirc 7 number 2 injector is the only the iscv plug will reach
Old Mar 9, 2009 | 05:05 PM
LHD220Turbo's Avatar
LHD220Turbo
sure you timed it up right?
did you use the old CPS? if so these are quite tempremental; give the connectors a clean and a wiggle
what about phase sensor? new or old
i bet its CPS (crank position sensor)
Old Mar 9, 2009 | 06:43 PM
cossie daz's Avatar
cossie daz
sorry ,do you mean idle control valve
Old Mar 9, 2009 | 06:46 PM
cossie daz's Avatar
cossie daz
put new CPS on and still doing it
It seems strange cos you can take lead off plug on number 2 and nothing changes but if you take other 3 leads off it changes noise ,if you no what i mean
Old Mar 9, 2009 | 07:36 PM
IANS2RST's Avatar
IANS2RST
yes m8, idle speed control valve
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
